7.3 mods - Ford Powerstroke Diesel Forum
post #1 of 26 Old 12-13-2012, 12:04 PM Thread Starter
powerstroke1098's Avatar
7.3 mods
What dio you guys think i would be seeing for horsepower with Rosewood budget stage 2's a Garrett GTP38R and tuning like a dp tuner or ts with custom tunes ? also would i need valvesprings and pushrodsm or a hpop? and whats the best clutch to get for that hp on the cheap side? and is their anything else id need
2000 Ford SCLB 7.3l F350 Zf6
Rosewood Stage II 160/80% Single Shots
Valair 500hp SD Clutch
TS Chip with Tuning from Matt@Gearhead
MBRP 4" TurboBack
Riffraff Frx & Riffraff Hpx
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
powerstroke1098 is offline
post #2 of 26 Old 12-14-2012, 12:27 AM
dentexpowerstroke's Avatar
First off, rating the injector by a stage isn't accurate at all. A stage 2 ranges from 160cc to 200cc. There will be a big difference in power between those 2. What cc size are you running. valve springs and pushrods would be insurance but aren't needed and for the hpop you will have to see if yours will hold icp with the new injectors. I'd look into tunes other than dp, but with good tunes I'd say 400-450 is a safe guess, all depends on tuning.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #3 of 26 Old 12-14-2012, 07:51 AM
Do you already have other mods?
2002 F250 Super Cab 4X4, 110k, Banks Ram Air, 5in Turbo Back Exhaust, FRX, HPX, CCV, Warn Hubs, Bilsteins 5160 with remote reservoirs all way around, Energy Suspension Bushings, Powerstop Slotted Roters, Crown Performance SS Brake lines, Autometer Triple gauges, TW 6pos Chip, Mag Hytec front and rear differential covers.... Runs Like a dream
Next on the list Transmission upgrades
chrisgrimes2186 is offline
post #4 of 26 Old 12-14-2012, 04:56 PM Thread Starter
i got a ****ty edge eveo 2 and i really only got it to monitor things im getting an exhaustthis week and i have an intake so i did the tree things everyone does but i have always had the intentions to build it, i really just want the best bang for my buck and in the 400's with hp, oh and i have traction bars
MBRP 4" TurboBack
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
post #5 of 26 Old 12-14-2012, 04:57 PM Thread Starter
i mean ladder bars
MBRP 4" TurboBack
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
post #6 of 26 Old 12-15-2012, 03:46 PM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
Do you plan on doing a fuel system?
As for the HPOP, what condition is yours in?
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 26 Old 12-16-2012, 10:32 AM
Sounds good...I would find someone with Autoenginuity to borrow or buy one if you want (or use something comparable) and test all of your system components especially your hpop and if everything is good then I would get a regulated return injectors and turbo and you should be good. but as far as power being made depends on how well your tuned but like it was said before stage 2 is wide range of injectors. Pin point a size you want and there could be some educated guess as to horse power. Riff raff diesel has a great package deal with injectors and turbo and FRX
post #8 of 26 Old 12-16-2012, 10:33 AM
But 400 can easily be made with what I mentioned
post #9 of 26 Old 12-16-2012, 10:41 AM Thread Starter
I was towing a 6000 lb trailer on the extreme setting once up a hill(I know its stupid but didn't see egt's higher than 900 and my probes in my manifold) I threw a code with no SES light for low or uncontrollable icp i think p1211? i've heard that means a weak hpop but i cleared it and haven't seen it again, and yes about the fuel system i was thinking a regulated return and a lift pump.
MBRP 4" TurboBack
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
post #10 of 26 Old 12-16-2012, 04:12 PM
Tuning can play a role in you getting the cel.
