Itake Spyder? - Ford Powerstroke Diesel Forum
Old 10-29-2007, 06:39 AM
Question Itake Spyder?
Looking for a intake spyder to fit early 99 that will fit 3" intakes.Also need to know if i have to change anything else?
Old 10-29-2007, 06:40 AM
International Threat
Isn't the turbo and uppipes different from the early 99 to late 99?
Old 10-29-2007, 06:46 AM
Might be? I bought the intakes and went to put them on an the spyder is smaller than intakes. Stock spyder is 2.25" the stock 1.75". do they make boots to fit?
Old 10-29-2007, 07:31 AM
I just need a little
Old 10-29-2007, 09:36 AM
I just went through the same thing ur goin through, i had to get a hole new spyder pipe and boots for the bottom, and if you put the bigger turbo on it you will need new up pipes and a turbo pedestal.
Old 10-29-2007, 10:02 AM
When you replaced the spyder did you have to change the turbo or is the spyder the same height as oe?
Old 10-29-2007, 10:09 AM
John Wood Nut Swinger
No such thing. Early99 is 2".
If you want to convert from early99 to late 99 you will need up pipes, pedestal, spyder, turbo and 3" intake plenums.
Old 10-29-2007, 10:11 AM
Well that bites I didnt want to do that much yet. I got 3" intakes from pa444 but did not think I would have to change that much.
Old 10-29-2007, 10:14 AM
I have the 3" spyder and pedestal from a 2002 in a box I will let go for $200 delivered. You would need the up pipes and turbo.
I upgraded to an H2E. I was going to do the same as you but I changed my mind half way through.
Old 10-29-2007, 10:23 AM
So whats the difference in height between the 2 or do you know? Also if possible do you think I could have it machined to fit?
