Replacing HPOP
I will be installing Stealth's srp 1.1 as soon as it arrives, does anyone have any tips or tricks they could share that would aid in the installation process? Also, is it recommended to change the ICP sensor or IPR valve at the same time? The truck has 151xxx miles on it.
I'd get a new ipr, you'll Need high pressure line disconnect tool, spray the ebp line with some penetrating oil, new fuel line o-rings, I changed my resivior oring/screen too
Sent from my iPhone using AutoGuide.com App |
Thanks |
Steve, Thanks for the advice! I'm thinking I might use the stock IPR for nor now unless it turns out to be bad. What are the symptoms of a bad IPR?
Rascal, Stealth was able to increase internal displacement by almost 37%. By adding new larger billet pistons and cylinder block combined with a new 17-degree billet swash plate. The pumps are designed with dual ABEC-5 ball bearings. They replaced the rear cover tapered section snap ring with a spiral lock retaining ring. A new billet rear cover is installed that has a raised o-ring boss. They machined the 3 high-pressure output ports from #6ORB fittings to #8ORB fittings and also machined the edge filter plug in the bottom of the pump and taken it from a #3ORB fitting to a #6ORB fitting. They also machine some of the internal passages to ensure proper flow in and out of the pump. |
What about just changing the mechanical portion of the IPR? Dieselsite offers that option for $75
That sucks! I went ahead an ordered a new one, just in case
Works good so far with stock sticks, thinking I should have 250/200's by April so I'll see how it goes then, I don't think I'll have an issue
Why would you want 200/200? just get 250/100...will empty out in 2.5ms and have better injection pressure= less smoke more HP and MPG's.
