cheap diy projects - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-26-2012, 05:59 PM Thread Starter
cheap diy projects
OK so I'm lookingfor some little DIY projects for my truck. Funds are tight now. Would like to find some more little projects? I have zoodad gauges intake exhaust tuner. I was thinking about installing a second stock 7.3 intercooler. What do y'all think? Effective? I don't like the plastic ends on the 6.0 intercoolers. Also considering visual mods. Again. I can diy almost anything. Access to almost any tool. And I can weld. Many junkyards near by. So Please give me ideas. Thanks.
ventryjr is offline
post #2 of 18 Old 11-26-2012, 07:52 PM
Joel's Avatar
Quoted: 10 Post(s)
Get some cheap steel and make a bumper. A rear bumper would be pretty easy I think.
I plan to do that in the spring
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 18 Old 11-27-2012, 03:17 AM Thread Starter
Thanks for the idea. I already am working on a front one though any more?
ventryjr is offline
post #4 of 18 Old 11-27-2012, 03:39 AM
I've always wanted to build a ram air scoop right above the filter, but with some way to completely seal it off also.
---David---
2000 Single Cab, 2x4, ZF-6
DIY 6637 Intake
PHP 6 Position Chip
5 Inch Custom Exhaust
Banks Gauges (Boost, Pyro)
High Pressure Oil and Fuel Crossover Lines
16 Inch XD Addict Wheels W/ Nitto Highways
david1991 is offline
post #5 of 18 Old 11-27-2012, 05:51 AM Thread Starter
Interesting idea. Were you thinking of a dual Hood scoop. Just the pass side being a fake for looks? I think it would be cool. Always looking for ways to lower egts.
ventryjr is offline
post #6 of 18 Old 11-27-2012, 06:28 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
+1 on the functional hood scoop that can seal.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #7 of 18 Old 11-27-2012, 09:22 AM Thread Starter
I have another ?. So when im at a dead stop and my tuner is set at 140hp and i step on it. My egts sky rocket ^^^ to 1200* quickly. so i lay off the throttle.So my question is. Can i safely go over that temp for short periods of time with out a load? If so what temp is to high? thanks guys,
ventryjr is offline
post #8 of 18 Old 11-27-2012, 10:56 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 35 Post(s)
As long as you're not immediately shutting off the truck afterwards, it'll be ok.
But be careful of doing that, heat cycling it like that will eventually cause a stress failure of some kind.
As for the functional hood scoop, I know it's not 'cheap' persay - but I'd love to get one of these hoods.
Hoods
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #9 of 18 Old 11-27-2012, 11:19 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Hard to talk about visual DIY mods when we don't even know what your truck is. Post up the specs and a pic or two.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #10 of 18 Old 11-27-2012, 03:13 PM Thread Starter
Oh yea sorry. 01 white dually cclb lariat. I'm gonna try to post pics later. And back about the egts what would be a max egt on a quick little drag?
ventryjr is offline
