Superchips Problem? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-27-2007, 01:38 PM Thread Starter
Superchips Problem?
I bought this Superchips Tunner on ebay and just received it and when I plug it in it does not turn on. I have the key in but the ignition turn in the off posistion but nothing. Has anybody ever heard of this problem before?
Thanks,
Rick
2003 Ford F250 7.3L
AFE Stage 2 Kit AFE 4" TB Exhaust.
cooper65 is offline
post #2 of 10 Old 10-27-2007, 01:55 PM
southern7.3's Avatar
I know a friend had a hypertech tuner and he forgot to return the programmer back to stock setting and we tried to install it on my truck and the same thing happened to me.
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
post #3 of 10 Old 10-27-2007, 02:07 PM Thread Starter
According to the manual if it has been vin loced it will tell you. But it seems to not be getting power.
cooper65 is offline
post #4 of 10 Old 10-27-2007, 08:29 PM
Cj Ford's Avatar
if it was vin locked it will tell you for sure...as soon as ya plug it in it should light up and give ya the superchips logo and the model ... sounds like the port is not powered check fuses.. if they are all good the tuner may be f*ed
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #5 of 10 Old 10-27-2007, 08:38 PM
Yep should fire right up. if you have another 96 newer auto try it to see if turns on to verify it isnt your truck.
MidwestOffroad is offline
post #6 of 10 Old 10-27-2007, 10:42 PM
teamcasslake's Avatar
Send a message via AIM to teamcasslake
u mentioned the key was in the ignition but in the off position. with my dads superchip microtouch tuner and most others i saw u have to turn the key on one click just dont start the motor.
hope that helps or even makes sense
teamcasslake is offline
post #7 of 10 Old 10-27-2007, 11:26 PM
sttstroke's Avatar
It should come on with out the key in the truck. Ive put mine on several trucks and worked fine, and then I was going to put it on the company truck and thats exactly what it did. I never did get it to work. But still works fine on others. Try it on another truck.
sttstroke is offline
post #8 of 10 Old 10-28-2007, 08:12 AM Thread Starter
I went to Autozone this morning and ask the guy there to plug in his scan tool and see if his worked, it would not power his up either we tried in the off posistion, on posistion and even started it nothing.
Thanks for all of you guys trying to help me out...
Rick
2003 Ford F250 7.3L
cooper65 is offline
post #9 of 10 Old 10-28-2007, 10:17 AM Thread Starter
Hey guys I found an open fuse that runs the cigarette lighter and the OBD II port. I replaced the fuse and it now works! I hooked up the Superchips tunner and upgraded the program and man what a difference, it reminds me of my 04 250 6.0.
Thanks Chris for sugessting to check the fuse. It always seems the simple things trip you up.
-Rick
2003 Ford F250 7.3L
cooper65 is offline
post #10 of 10 Old 10-28-2007, 07:24 PM
Cj Ford's Avatar
no problem Rick .. glad I could help.. it sucks when ya try to add horse power and something stops ya.. gotta fix it quick
Chris
Cj Ford is offline
