Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
  #11 (permalink)
Old 10-29-2007, 01:24 PM
CSIPSD CSIPSD is offline
Originally Posted by HorseMover View Post
What do you guys think about the thermocouple options - drill/tap the manifold or use the clamp style on the turbo down pipe. I thought that I read that the manifold was a better read?
Originally Posted by 460+ View Post
Ive got mine in the down pipe some say its better in the manifold, but if its only reading one bank whats the other doing. Semis are in down pipe.
There are only two place's a Pyro Probe should be, in the UP PIPE or in the Manifold... The down pipe is the WORST place you can have it.
If your pyro is in the down pipe you must use 1000 as your red line, because any higher then that and you have NO IDEA what the pre turbo temps are. If its in the down pipe, MOVE IT...
First pic is a drill and tap, clean and neat, can be plugged later if needed.
Second pic is a drill and clamp, Very quick, works good, can leak sometimes.
Third Pic is the #7 piston from an early 99 and a post turbo pyro using an 1100 red line.
File Type: jpg What a post turbo pyro and 1100egt red line get you....JPG (71.6 KB, 16 views)
  #12 (permalink)
Old 10-29-2007, 01:29 PM
HorseMover HorseMover is offline
Sorry - I meant up pipe. Thanks for the information!
  #13 (permalink)
Old 10-29-2007, 02:42 PM
cstroke69cpy3 cstroke69cpy3 is offline
Gauges are easy to install... First timer... about 5 hours with all the prep work included...
What gauges you ask...
gauges not to bad, im not great with wiring either.. 5 hrs pretty accurate.. just follow the install sheet diesel manor sends you and its pretty straight forward..
  #14 (permalink)
Old 10-29-2007, 04:51 PM
powerstrokin87 powerstrokin87 is offline
Send a message via MSN to powerstrokin87
im looking into getting a 4 guage pillar. i already have a recon that monitors boost and egts. although i think im goin to go with a mechanical boost guage, oil pressure, water temp, and i need one more to fill the 4th spot any suggestions? i was thinkin maybe oil temp? alos what degree range do i need for the water and what pressure for the oil? i have put these kind of gauges on gas trucks but im just not sure about a diesel motor if the pressure and temp ranges are different.
  #15 (permalink)
Old 10-29-2007, 05:06 PM
Fuel Pressure... Next to pyro and tranny temp, lack of fuel pressure can leave you on the side of the road...
