injectors?
Rebuilding a 02 7.3l and would like to install bigger injectors how Much bigger can I go without to many modifications planning on Putin in head studs and replacing turbo compressor wheel . cold air intake
160/stock and at that you are already over doing it for your turbo.
"Stage 1s" is what your after, they come in minor variations
Travis T 1999.5 F350 CC 4x4 (mine) 2002 F250 CC 4x2 (wife's) |
160cc single shots should run on your stock HPOP. you prob want to install a regulated return and oil xover with bigger injectors anyway
160/100 is prolly the biggest you wanna run, not to mention your gonna need custom tunes. While your in there, might not hurt to put a bigger exhaust housing on your outlet side of the turbo. Help with flow some more
I would never run a 100% nozzle on a stock sd turbo, the .84 housing is a killer. With 180/100 my stock turbo lasted a whole 2 months. A van turbo lasted 4 months before it got replaced with a s366 and the van turbo had zero shaft play after that. The .84 housing on a stock sd turbo is WAY to small and the turbo is to weak for anything over a 160/stock really.
