Why not Superchips?
Just purchased a 2001 F250 Lariat 4x4 Crew. Everything on the 7.3 is stock, putting a 4" exhaust on soon. Prior owner had a Superchips Micro Max Tuner that he gave me with the truck. I see a ton of recommendations on the DP chips. I am confused. The Superchips tuner I just plug into the port and it rewrites the program but this DP has a circuit board, what's the deal with that? I think I can trade in my old tuner for a newer Superchips for a couple hundred bucks. Is there some amazing advantage to the DP set-up that would justify the extra expense? It looks like the F6 id $400 without codes? Can somebody explain all this and chime in a/b why Superchips doesn't seem to get any love in the forums.
im not speaking for the forum.
but my bet would be a canned tune thing. not many on the site seem to like/support the idea. my opinion is you need to do what works for you. a edge tuner (one of the plug in ones like superchips) came with my truck its not as easy to use at the 6pos switches....one day ill upgrade to one, but for now....it works fine for me. basically what im saying is- do your thing man. |
The customer service on Superchips SUCKS....Dont Buy Superchips, just for that reason alone!!!!! DP or TS are pretty good chips, they will give you better power and more options. That my two cents.....
But I already have a Superchips (3 programs - Hi Perf, Perf Tow, Safe Tow), my question is what would be the real world gains by switching to DP? I'm trying to make a cost benefit analysis of purchasing a DP or TS as compared to just staying with what I have.
Superchips uses canned tunes, that is one size fits all. They make generic tunes that fool the PCM into doing what they want. A REAL tuner will ask you for your PCM code to make sure they are giving you the most accurate tunes available. Superchips does not. One size fits all is easy, but not the best.
If your truck is stock leave it but if you do any other upgrades (turbo, injectors, shift kit, etc.) you deff want custom tunes.
Sent from my iPhone using Autoguide.com App |
I got a Cortec Superchips and thought it was the bomb. Superchips is not a popular item on here. But as far as customer service I think there quite good. Bottom line is sct 3 custom tunes, ficm upgrade, will put your truck in a different world. If thats all the pocket money you got then use it for now. JMO
i had a superchips tune on my old '99, and thought it was awesome compared to stock.... BUT, that was before i really started learning about diesel performance... since then, i have learned tons... one of the most important things is egt's... i would suggest, since you allready have the superchips tuner now, that you get some guages and see what that tuner is doing to your engine, and then decide what you would like to do from there... superchips is notorious for really high egt's....... personally, i would not go with that style of tuner, because you have to stop and screw around with it to change the tune for towing or whatever... and being limited to 3 tunes is lame, especially, as previously stated here, they are "canned tunes"... go with a custom tuner like tony wildman, php, beans.... etc.. get a shift on the fly 6 position chip.... way worth the money! it'll run better, with lower egt's, it will shift better, you can change it whenever, while driving.. you will love it.....
Not only are they "canned tunes", but they aren't very good ones either
It's easy to make more power with just a few simple changes (stuff you can actually do yourself with resistors/diodes) but it takes someone with Real understanding to do it right. You've seen the names, you know who they are, they Don't work for Superchips ![]() Also. their poor programming is awfully hard on the 4R100 (already a weak link for us)... |
