Gauges came in UPS today! Couple questions. - Ford Powerstroke Diesel Forum
Old 11-09-2012, 04:52 PM
Ordered an ISSPRO gauge kit from DieselManor, any quick tips on install, maybe things to look out for? I plan on doing it in the morning. Also my PHP Phoenix will be here Tuesday or Wednesday next week!
Thanks fellow PS fanatics!
03' F-250
7.3l
Leveling kit on 33's
5" Flo-Pro exhaust
Cold air intake
PHP Phoenix(coming soon)
Old 11-09-2012, 11:53 PM
Pretty straight forward. Be very careful with the manifold. Mine has 2 "sets" of threads in the bore because I messed up. I got very lucky and the probe took to the second set with no leaks, but dont count on being so lucky. Take it nice and slow. If you tap the intake manifold, same thing, but I would suggest an AIH plug, it's cleaner.
Old 11-10-2012, 11:02 AM
I used a tee in the boost sensor hose, But i later got a AIH delete plug from Riff Raff diesel so I may move it to that port, when you drill the port in the exhaust manifold start with small drills and work up to the final size that will keep the chips small. when I did mine I also took a pice of steel wire and taped a magnet to it and fished around in the hole to get any chips out and I used a vaccum to make sure it was clean!
Old 11-10-2012, 11:29 AM
Thanks for the advice guys, gonna do it tomorrow morning, the ol' lady kept me from it today! Haha
03' F-250
7.3l
5" Flo-Pro exhaust
Cold air intake
Old 11-11-2012, 07:47 AM
use wax on the drill bit as well as the tap.... makes thing sooo much easier...
