intercooler install ? - Ford Powerstroke Diesel Forum
Old 10-24-2007, 03:58 PM
Well I am finally gonna put the 6.0 intercooler in my truck but as most people know the tranny lines are in the way.
So my ? is can I cut those lines that go into the tranny cooler then splice and redirect them? Or do they have to much pressure for a hose clamp or two?
~Jim
Old 10-24-2007, 04:16 PM
I think a couple of hose clamps on each side should be fine. Of course, mines a 6sp, but I've put tranny cooler's on other cars like that with no problem
Old 10-24-2007, 04:18 PM
i cut mine when installed my secondary trans cooler with no problem... i didnt even put a clamp on it their was only very minimal seepage....
Old 10-24-2007, 07:33 PM
Here is a pic of a bracket I made, lowering it about 2", easy cheesey
intercooler install ?-drop-bracket-tranny-ps-coolers.jpg   intercooler install ?-lowering-bracket.jpg
Old 10-24-2007, 07:38 PM
what kind of gain do you get by putting the 6.0 intercooler on a 7.3 and what does it cost....
Old 10-24-2007, 07:40 PM
gain is lower EGT's because the 6.0 is a lil bigger... and you can usually find them on ebay for around 300 bucks
Old 10-24-2007, 07:43 PM
do you need any kind of connecting boots or does it use the same hardware,- the trans lines
Old 10-24-2007, 07:45 PM
you would need diff boots.....because the holes on the 6.0L IC are a lil larger
Old 10-24-2007, 07:48 PM
You need some new boots, and a few clamps... IMHO its not really worth the trouble, I saw nothing empty and maybe 50-75 when loaded... I cut and extened my passanger side tube, but you can just order longer boots from NAPA...
intercooler install ?-extended-tube.jpg   intercooler install ?-pb050005.jpg   intercooler install ?-top-view-size.jpg   intercooler install ?-6.0-installed.jpg   intercooler install ?-removeing-core-support.jpg
where can you get them and how much does it lower your egt
