7.3 Edge Juice with Attitude - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-03-2012, 04:03 PM Thread Starter
I've been thinking about the Edge Juice with Attitude and i was wondering if you could stack it with another programmer.
JohnathenB is offline
post #2 of 8 Old 11-03-2012, 04:28 PM
Turbostang500's Avatar
Not a Dodge forum.
Search "edge juice with attitude" on here and you will find out the average feeling about Edge and their tuning.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #3 of 8 Old 11-04-2012, 12:01 AM
AOx4's Avatar
Originally Posted by Turbostang500 View Post
Not a Dodge forum.
in fact, you can even apply the quote in the bottom of your sig
Stay away from Edge tuning, and "stacking" anything is just bad.
- Trey
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, OEM Black CPS, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
AOx4 is offline
post #4 of 8 Old 11-04-2012, 06:29 AM
Supporting Vendor
Well, if the Juice was actually a programmer, you wouldn't be able to. However, since the power function of the Juice has always been simply an injection pressure fooling device, then by all means, it's "stack-able". You can use it with either a flash programmer or a chip. Will you see any power gains by using it in conjunction with either tuning device? Nope. It will make the accelerator pedal more responsive and add a bit of fuel in the lower RPM ranges but once the high pressure oil pump has reached it's limit, you won't see any gains above what the programmer or chip was capable of in the first place.
Again, the Juice is not a programmer so therefore it doesn't have any "tuning" on it. It's a variable resistor for all intents and purposes. The CS and CTS Juice/Attitude devices include a transmission tuning option to alleviate the effects the older Juice modules had, but the power gains still come from fooling the injection pressure input to the PCM because the Juice module is STILL a Juice. The display (Attitude monitor) does the transmission programming only.
The Juice doesn't contain any "tuning" for the engine. "Stacking" these devices on a 7.3L isn't really "bad" per se, but there is little reason to spend the money on two devices that will only run just as good as aftermarket programming would by itself (Evolution, Superchips Max line of programmers, Hypertech, or any level of tuning for stock injectors that any of the "custom tuners" does, etc.).
The
I'm not a jerk, I just tell it like it is.
1995 SC/LB 4x4 PSD/Auto
2000 RC 2wd PSD/Auto
PHPDiesel is offline
post #5 of 8 Old 11-04-2012, 06:35 AM
Good info to know and even more reason to NOT run Edge products.
Thanks!
Lee
[/URL]
post #6 of 8 Old 11-05-2012, 11:55 PM
dentexpowerstroke's Avatar
The
I honestly have not ever seen it described this well. It's as if you have worked for edge/ wrote their tuning, or at least know the guy that did haha. Thanks bill or the one at php who checks this site.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #7 of 8 Old 11-06-2012, 12:52 PM
Supporting Vendor
Thanks.
Nope, not Bill, but I do 7.3L tuning for him part-time.
post #8 of 8 Old 03-03-2013, 12:47 PM
hooperduty's Avatar
i just got a cs attitude from a buddy but dont know too much about tuning yet and im still getting into it. right now my truck is a DD and i tow during the summer. from what i have read on here, the edge cs attitude is not good? and doesnt really allow you to tune your truck?
my main question is did i just waste my money and time, and should i take it off the truck before i do any real damage?
hooperduty is offline
Tags
1999 7.3l , 7.3 diesel , edge juice with attitude , stacking
