Fuel Pressure Relief Housing Spring?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-20-2012, 03:06 PM Thread Starter
tallyF350's Avatar
What is the benefit or effect of using a higher pressure spring on your fuel bowl?
2002 F350 SWB
Mods: 07 front end- 07 front&rear tough country bumpers linex- 08 mirrors power fold- replacement bed and 2010 tailgate- new paint-new leather interior- new steering wheel- 05 folding rear seat-35 10.5 20 Toyo PT and 20" Krunk Fuel Rims- AMP Research Steps- Rancho 9000 shocks- New HUBs - Ball Joints - Draglink- Track Bar- Sway Bar End Links-
tallyF350 is offline
post #2 of 11 Old 10-20-2012, 03:55 PM
AOx4's Avatar
To increase (or rather maintain) fuel pressure at high fuel demand.
When at WOT you will use more fuel, pressure will drop. Using a higher pressure spring helps maintain the fuel pressure in the safe zone of 60-70psi
- Trey
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, OEM Black CPS, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
AOx4 is offline
post #3 of 11 Old 10-20-2012, 04:44 PM
CSIPSD's Avatar
This is assuming your having a pressure issue.
It is NOT a performance mod.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 11 Old 10-20-2012, 04:52 PM
AOx4's Avatar
Its a supporting mod.
- Trey
AOx4 is offline
post #5 of 11 Old 10-20-2012, 06:18 PM Thread Starter
tallyF350's Avatar
Since I am rebuilding the fuel bowl and have the three springs to choose from, would it be best to use the 50psi or 60psi or 70psi?
2002 F350 SWB
post #6 of 11 Old 10-21-2012, 10:42 AM Thread Starter
tallyF350's Avatar
I went ahead and used the middle silver spring 65psi.
2002 F350 SWB
post #7 of 11 Old 10-21-2012, 10:58 AM
CSIPSD's Avatar
The correct thing to do would be check your fuel pressure. Right now you could have anywhere from 40psi to 100+ psi. You dont know.
Joe
CSIPSD is offline
post #8 of 11 Old 10-21-2012, 03:53 PM Thread Starter
tallyF350's Avatar
How do I check fuel pressure? I have a Edge Evolution on the way; will this show fuel pressure?
2002 F350 SWB
post #9 of 11 Old 01-09-2013, 06:30 AM
machinestheman's Avatar
i had the same one or have rather and the highest spring it came with shot up over 100 psi as soon as i hit the key i run the middle one puts me right at 74psi but like stated before i wouldnt go chancing anything without a guage they sell a fuel bowl adapter that gets you to standard pipe thread then just screw in a guage or fuel pressure sending unit that will work with your monitor either way you will need the adapter i believe i got mine from the diesel orings site aswell
01 f 450 6sp 4WD
DIY intake with prefilter, CCV mod, IAH delete, Granatelli big G monitor with electronic fuel pressure sender, sinister diesel coolant filter, muffler delete and hollow cat, IH bellowed up pipes, polished intake spyder, 203 thermostat, billet fpr housing, hpx hard line.
machinestheman is offline
post #10 of 11 Old 01-19-2013, 10:56 PM
Ramsmoker's Avatar
Fuel pressure is a performance modplus it removes air and vapor from the fuel for a better burn. For $10.00 fom Dave at DI you can put his kit on with an exturnal reg. so you can try it where ever you want in a split second. I've run from 2 to 150psi in mine you will see how it changes.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
