Stock Turbo Max Boost? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-16-2012, 04:27 PM Thread Starter
Jake.'s Avatar
2000 F-350
Hypertech stage 3 tuner (out dated but works great)
6637 intake
straight piped
Im only making 21 pounds of boost, is this normal for a stock turbo? Is there ways to pound more boost out of it?
2000 7.3l F-350 CCLB DRW
1983 F-250 6.9l
Jake. is offline
post #2 of 11 Old 10-16-2012, 04:32 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
You need a boost cooler to tell the computer to stop defusing. Also, a better set of tunes will work wonders. I saw 26 with tony wildman tunes.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 11 Old 10-16-2012, 04:42 PM
AOx4's Avatar
The stock turbo will only make about 27psi max. This is further limited to 21psi by the PCM. Get a REAL tuner (or boost fooler if you are cheap) and you can get that last 6psi.
- Trey
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, OEM Black CPS, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
AOx4 is offline
post #4 of 11 Old 10-16-2012, 04:54 PM
Doesn't Even Care
Quoted: 69 Post(s)
On a consolation note, the turbo will make more, but you need more fuel. I spooled 34 psi on stage 2s on a stock charger.
Nick
"The Mistress"
post #5 of 11 Old 10-16-2012, 05:10 PM Thread Starter
Jake.'s Avatar
Im thinking about getting a TS 6 position tuner. what would you recomend for tunes? I drive this everyday to work about 75 miles round trip and occiosnly pull a bobcat. also its a 6 speed. so with my hypertech im running about 18 to 20 mpg.
1983 F-250 6.9l
Jake. is offline
post #6 of 11 Old 10-16-2012, 05:12 PM
AOx4's Avatar
Ive got PHP tunes. They are good, so is DI.
- Trey
AOx4 is offline
post #7 of 11 Old 10-16-2012, 05:37 PM
Doesn't Even Care
Quoted: 69 Post(s)
Php is good tony wild man is another good one. Beans, gear head ....
Nick
"The Mistress"
post #8 of 11 Old 10-17-2012, 04:08 AM Thread Starter
Jake.'s Avatar
On that note. If I start adding boost and later in the future I get a larger turbo, injectors, ect.... will i need to install head studs? How much abuse can these 7.3's take before a guy should install studs?
Most of the guys I run with are pushin commins and im a diehard ford guy, This is my first stroker and I dont wanna take advice from them..
1983 F-250 6.9l
Jake. is offline
post #9 of 11 Old 10-17-2012, 06:34 AM
Agreed wit hthis.
Agreed with this also.
Hypertech is junk. Beans or Tony Wildman. Make sure to get a tow-tune.
Head studs, 40psi+. Not typically a big deal on these trucks.
And whatever you do, dont listen to the Cummers.
85_305 is offline
post #10 of 11 Old 10-19-2012, 10:57 PM
dentexpowerstroke's Avatar
I'd look at TW, gearhead or beans for tuning. Don't worry about headstuds unless you are pushing some power and see 40psi often. I'm running 250s and I don't have headstuds yet. A good tuner will manage cylinder pressure so you don't have to worry about blowing hgs.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
