I NEED MORE - Ford Powerstroke Diesel Forum
Old 10-21-2007, 09:48 PM
Send a message via AIM to RSTRONG85
Exclamation I NEED MORE
newb here with a 2000 f250 4x4 psd. i only have a 4 inch down pipe on my truck im in the middle of finishing it i want to end up with 5 inch turn out stacks anyways im gonna have the springs rearched to level me and add some 33 inch all terrains .. ONTO THE POWER i want power but safety i plan on putting a 6.0l tranny and charge air cooler in i heard only few mods are needed to do this and they are significantly larger but my truck has 160k on it and a everyday driver i want water meth inj and a bad *** controller/ module that is on the fly i dont care if it has gauges or if i have to buy mechanical ones... WHAT I REALLY WANT TO KNOW IS WHAT IS THE BEST BANG FOR THE BUCK WITH ADDING THE MOST POWER WITH HAVING THE MOST SAFETY. I have about 4 grand to work with im in the rochester ny area.
Old 10-21-2007, 10:20 PM
$4k for performance mods? Hell... here's what I'd do...
AFE Stage 2 Intake with Proguard 7 filter
AFE pre-filter
put 4" exhaust on if the DP is all you have
Good set of guages (EGT, Trans temp, Boost) or a Quadzilla Commander or equivalent digital guages (just saw a Dashpaq being talked about and looks SWEET!)
Tony Wildman or DP Tuner flip chip
Snow stage 3 water/meth injection
do the 6.0L IC and trans cooler upgrades.
you should have plenty of power with that and only be about halfway or 2/3 into your budget. Then you can decide on bigger injectors or a dual hpop system or lots of other options
Old 10-21-2007, 10:21 PM
i would add a tripple disck TC and valve body to the list...
Old 10-21-2007, 10:24 PM
oh yah, I was just gonna say and save the rest to put toward a tranny rebuild...lol
no need to waste money on a TC or VB with a higher mileage trans taht will likely need to be overhauled soon....specially with the extra power`
Old 10-22-2007, 12:12 AM
ditto^^^^^
Old 10-22-2007, 01:02 AM
COLLEGE KID
Send a message via AIM to lifewitlooie
Yeah, ive read some threads lately about trannys will get fried much quicker even with the safe mods.
Old 10-22-2007, 05:22 AM
when you guys say afe kit ive heard about the diy kit which one is better a drop in afe filter in the oe box, diy intake tube or afe cold air kit i would eventually like to get a functional hood. eBay Motors: 99-03 FORD POWERSTROKE INTAKE KIT 7.3 SYSTEM WITH AFE (item 120172606851 end time Oct-22-07 18:05:46 PDT)
what ab out this?
Old 10-22-2007, 05:31 AM
where can i get a good tc and valve body kit and what about that chip can it be programmed for tranny shift points and such i want it to SMOKE out of those dual 5 inch stacks
Old 10-22-2007, 05:33 AM
what is the advantage in doin the foil delete
HAHAHA IM SO FULL OF QUESTIONS....
Old 10-22-2007, 05:34 AM
and what benefit does the banks wastegate actuator do for you?
