238/100 rosewoods? - Ford Powerstroke Diesel Forum
Old 10-08-2012, 09:13 PM
238/100 rosewoods?
I'm looking to due injectors and turbo upgrade in the next few weeks. I was wondering if the 238's were gonna be to much for a d66. I do have a t500 hpop and a ts chip I will send out for custom tunes. I'm thinking I may need some trans upgrades too. What do you think? Thanks.
Old 10-08-2012, 10:47 PM
I think that'd be a pretty solid setup. The only thing I would recommend is check your fuel psi. With a healthy pump I held fuel psi on 180s but the guy I sold those to said his dropped pretty quick. You may want to look into a different fuel pump setup.
Old 10-08-2012, 11:15 PM
T500 not enough?
Old 10-09-2012, 02:22 AM
Fuel pump not hpop.
Old 10-09-2012, 12:44 PM
I ran a Holley blue pump a couple of my 24v's with success, would that push enough fuel for a powerstroke?
Old 10-09-2012, 12:51 PM
Don't know what they flow. I'd look at the walbro pump or a bosch 044. That will be a pretty sweet setup. Only other issue I see is at that level you may want to look into studs and valve springs as a precaution.
Old 10-09-2012, 12:54 PM
It's rated for 110 gph.
Old 10-09-2012, 12:59 PM
I've read that with this combo I should be pushing no more than 32 pounds of boost. I thought head studs were recommended for over 40?
Old 10-09-2012, 01:09 PM
How would the d66 and stock injectors run? The problem is I only have $4000 to spend. Don't know if I should do injectors or turbo?
Old 10-09-2012, 01:38 PM
I don't think the stock turbo will last long with the 238s as well be running out of the efficiency of the turbo. You might look around and find a used turbo in good condition and get more than the d66 keep your eye out and if your not in a hurry there is some good deals to be had.
