Regulated Return
I have searched/read 30+ post and can not believe that a regulator, hoses, 2 filters/housing's cost $1,000?! Im looking to upgrade prior to ordering my stage 1's for now. Was looking at Riff Raff FRx but the regulated return is obv better. I did find one build for $400 but the hoses they used from JEGS says on JEGS webpage do not use with oil based products. Does anyone know a reasonable build with link that im missing?
get a aeromotive A1000 regulator and build your own much cheaper
That $1,000 also included a pre-pump/ intank kit filter kit on my setup. You pay to play I guess.
Where were you looking for RR's? There's quite a few DIY setups. Last edited by Toms01PSD; 10-04-2012 at 12:50 AM. |
the bigger question is, why do you want an RR for only stage 1's??? Just do an hpx/frx and call it a day.
Stage 1's for now... Will be upgrading eventually
For stage 1's you dont need no RR setup. If you want, do an frx/hpx and call it a day. $60 in parts right there, not $1,000
No denying that the RR is nice though... I did mine because of the plans I'm saving for.
Sent from my iPhone using Autoguide |
It is a nice setup, its just not a need for only stage 1's.
You can build a full hard-line stainless steel regulated return for around $250-300.. majority (if not all) can be found on jegs.
Like previously said, a FRx and HPOx will be good for where you are now.. but if you have bigger plans for the truck, then a DIY RR system would be great. Sent from my DROIDX using AutoGuide.Com Free App |
RR
RR is great if you can't get ride of you air. You will need more fuel pump to keep up with the retur flow. With out the air to start with you can do away with the return line and just pressurize the rails. I use a Walbre marine pump that will run at 150psi all day so it never works to hard.
