Edge CTS question
I have read through the threads and cant seem to find a detail of what is needed to properly monitor Pyro-Trans temp, and Boost on the Edge CTS.
So here is my question: I have a late model 2002 F350 4X4 crew cab. will I need to run sensors to monitor Pyro and trans temp? I am trying to decide between analog gauges and edge CTS. ![]() Thanks!! |
Sensor will be needed for your EGT. As for trany temps it will get the info from your truck. I do believe they do have a sensor that will plug into your trany if you want to go that way.
I've got the Edge CTS and it monitors trans temp and boost. For the CTS to monitor EGTs, you have to buy the optional sensor that comes with the connections to the CTS.
