Aluminum of Stainless exhaust questions?? - Ford Powerstroke Diesel Forum
Old 10-20-2007, 09:31 AM
Send a message via AIM to teamcasslake
would a aluminum exhaust have lower egt's then a stainless??? sense aluminum displaces heat fast????
Old 10-20-2007, 09:33 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
The exhaust is moving so fast that any difference would be negligable.
Old 10-20-2007, 02:30 PM
yah, neither will matter in EGT's -- only real advantage is looks and longevity certain climates
Old 10-20-2007, 03:13 PM
Rob Rob is offline
the EGT's are produced in the combustion chamber so what ever exhaust you had would make no difference. the only difference in the metals is the longevity like brant mentioned.
Old 10-20-2007, 03:22 PM
You don't actually want the exhaust piping to dissipate heat. The higher the temperature, the faster the exhaust gasses flow. That's why you see high temp tape wrap or ceramic coatings.
I don't know of anyone offering actual aluminum exhaust for the Powerstroke trucks. Probably what you are looking at is aluminized steel. An all aluminum exhaust kit would be hella expensive.
