Oil in coolant - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-22-2012, 09:01 PM Thread Starter
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Oil in coolant
Was looking in my coolant bottle today in my colleges AutoLab and noticed a black residue around the top. The shop teacher and I determined it was motor oil, One of the former students who now works on Big Rig diesels said I might have a leak in one of my head gaskets I talked to my friend who works on them and he said something about the oil cooling system above the filter and most of the time that is the cause of the oil in the coolant. I was woundering how much time will it take to fix the oil cooler? Im hoping it isnt the heads
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #2 of 7 Old 09-22-2012, 10:30 PM
dentexpowerstroke's Avatar
Injectors cups or oil cooler. Either one is pretty easy to fix... hopefully someone will chime in of how to determine which one of these it is, haven't dealt with either so I'm not familiar on diag on these.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #3 of 7 Old 09-23-2012, 11:00 AM Thread Starter
The guy that worked on the big diesels said they use a vacume device on the coolant bottle with a ball in it to see if the combustion pressure is coming up. Basicly if nothing the ball stays still if there a leak it bounces
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
post #4 of 7 Old 09-23-2012, 07:06 PM
I haven't heard many head issues on a 7.3. Has your truck puked at all?
post #5 of 7 Old 09-24-2012, 05:58 AM
Injectors cups or oil cooler..
Yep sounds about right
85_305 is offline
post #6 of 7 Old 09-24-2012, 06:17 AM Thread Starter
define puked. I havnt noticed any coolant coming out or the black residue running down the bottle. have had some water drip out by the passanger side front wheel but thats it
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
post #7 of 7 Old 09-24-2012, 11:02 PM
444 ci's Avatar
its your oil cooler my truck did the same thing. either the seals in your oil cooler are bad or the inside of your oil cooler is rusted out causing you oil and coolent to mix. it cost me about $ 700 to get mine fixed but the shop put in a brand new oil cooler.
444 ci is offline
