need more black smoke/speed - Ford Powerstroke Diesel Forum
post #1 of 25 Old 10-18-2007, 09:34 PM Thread Starter
paulmacjr's Avatar
Talking need more black smoke/speed
ive just got a 2002 ford ex diesel 7.3 4x4 with 65000 miles
and i just installed a ts perfomance chip and it dosent produce quiet enough power and black smoke that im looking for so what do i need to get now to produce alot of smoke, and alot of horse power?
paulmacjr is offline
post #2 of 25 Old 10-18-2007, 09:36 PM
Raul@Stealth Automotive's Avatar
you got supporting mods like intake and exhaust?
Raul@Stealth Automotive is offline
post #3 of 25 Old 10-18-2007, 09:48 PM
get some custom tunes if you have the supporting mods....
Blue01F250 is offline
post #4 of 25 Old 10-19-2007, 06:02 AM
CSIPSD's Avatar
What have you done? If you've done all the little things like intake and exhaust... your at a point that you can add drugs (ok but hard on the motor) or add fuel (better, but expensive) ie injectors...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 25 Old 10-19-2007, 08:14 AM
CUMMINS_KILLA99's Avatar
ARE YOU CRAZY MY TS ROLLS ALL KINDS OF SMOKE WHAT ARE YOU TRYING TO DO BLOCK OUT THE SUN DEFINATELEY GET INJECTORS
99.5 F-250 4X4 LARIAT
35IN. BFG KM2s
2.5 IN. LEVELING KIT
AEM AIR INTAKE
TS CHIP (TUNED BY MATT @ GEARHEAD)
GARRETT 38R TURBO
6.0 INTERCOOLER
4IN. TURBO BACK EXHAUST
CSE FAB SINGLE BLACK 8IN. SLASH CUT STACK
CCV MOD
CSE PRE PUMP KIT
TRANNY COOLER WITH FAN
CSE FAB PORTED EXHAUST FLANGE
TIM MOYE TRANSMISSION
CUMMINS_KILLA99 is offline
post #6 of 25 Old 10-20-2007, 11:07 PM Thread Starter
paulmacjr's Avatar
well i just ordered a afe stage 2 and know im going to straight pipe the exhaust after that i need to get some better gauges, and one got a good suggestion on what type and brand?
post #7 of 25 Old 10-21-2007, 03:59 PM
Send a message via AIM to farmboy930
i put the pricol optix gauges boost and pyro on my pillar and im verry pleased really clear and work great also you wouldnt be dis-pleased with your afe stage 2 i love mine
2000 F 250 crew cab short bed
Silverline 304ss turbo back, AFE stage 2 intake
Pricol Optix Boost and Pyro gauges, Whicked Wheel
Elite Diesel XCAL2 tow power,high power,max power
1999 F 350
Farmers custom straight exhaust w/ 5" tip
Farmers custom intake
Edge Juice W/ Attitude
farmboy930 is offline
post #8 of 25 Old 10-21-2007, 08:37 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Well what do you want, smoke or power? Put injectors in and you get smoke along with more heat, and maybe some added power but you're just doing something that's pretty stupid. Put a better charger on to burn off all the fuel and make more power!
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #9 of 25 Old 10-21-2007, 09:44 PM Thread Starter
paulmacjr's Avatar
whats a good type of injectors to put in to this truck for mid power? ive seen theres a few types out there and stage1,2,3 and a hybrid stage?
post #10 of 25 Old 10-22-2007, 10:29 AM
CSIPSD's Avatar
With a 02 you have PMR rods, so best keep it under 400hp... If you want to stay safe, go with a set of stage 2 single shots and a Turbonetics Ball Bearing turbo. This, with supporting mods, will put you right at 380-400hp. Isspro Gauges is what I run, all 16 of them.
I really prefer Hybrid injectors and then Detune them... but it is running on the ragged edge.
Joe
CSIPSD is offline
