dptuner stacked with... - Ford Powerstroke Diesel Forum
Old 10-16-2007, 06:21 AM
can you stack a dp tuner chip with anythign?
Old 10-16-2007, 06:26 AM
no, you cant stack chips on a 7.3L. The DP tuner chip will override any other program that you might have installed on the truck. So such thing as stacking on our trucks.
Old 10-16-2007, 06:29 AM
what about chip with edge juice
Old 10-16-2007, 06:36 AM
a chip that plugs into the PCM will override any other type of programmer that you would install thru the OBDII port or something like an edje juice. If it plugs into the PCM, thats the only program you truck is going to run on, no stacking.
yea or edge evo with edge juice with attitude?
Old 10-16-2007, 06:41 AM
y dont they allow stacking?
Old 10-16-2007, 06:43 AM
the chip (DP, TS, etc.) will fully override the other type of programmer installed on the truck. The chip connects directly to the PCM and that is what tells the truck what to do, therefore OVERRIDING the programmer and running only the chip.
Old 10-16-2007, 06:47 AM
why would you want to stack on top of a DP? the DP will be way more efficiant than the Edge stacked on top of it.....the juice is a module and it can be stacked on top of programmers like the evo but it can not be stacked ontop of a chip... either way the DP will out perform the juice stacked ontop of a programmer....
Old 10-16-2007, 06:49 AM
Old 10-16-2007, 07:18 AM
i already have the juice and was thinking of getting a chip with 1or2 stages with lots of power and running the edge mileage on the highways.
