Twin stock transmission coolers - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-08-2012, 02:44 PM Thread Starter
This is for my 2000 7.3 Excursion
On my 2003 7.3 F250 I have a 6.0 trans cooler installed, I plan on doing the major hauling with it 10k +, on the Excursion I want to pull a 18ft car trailer to Wisconsin next week, well I havent pulled anything with thing yet. Just got it about a month ago and have been doing all the maintance on it, if it had a fluid it's need changed if it was a filter it was changed.....EVERThing.
Anyways I have another NEW stock 4r100 trans cooler that I am wanting to install on top of the stock one in there and run them in series. If you flip the cooler upside down, you can attach it from the center attachment points, then the connectors will be on the drivers side of the radiator. Then connect them together.
Do you think this will be plenty for the old girl, should double the cooling capasity, or I was thinking about mounting another compact cooler under the frame with a fan on it. I like the idea but the simplicity of double stock coolers can't really be beaten.
Let me know your thoughts, my 2003 trans temps pulling 16k of trailer/cars runs about 170 with Texas average outside temps of 95-100. So 70f is pretty good
2003 Ford F250 Crew-Cab 4X4 7.3L 350HP
2000 Ford Excursion 4X4 7.3L
1993 Mazda Rx7 Coup 1.3L 574HP
2003_F250_FX4 is offline
post #2 of 15 Old 08-08-2012, 06:30 PM
Guns & Powerstroke's
HillClimber350's Avatar
Sure seems like a lot of cooler to me. 70 over isn't bad. Once you get on highway and your tc is locked your temps will drop. May not need anything else
2001 F-250 Platinum Edition
BTS Trans, 6.0L Cooler, DP Tuner, AFE Stage 2 Intake, 4" turbo back, Bean's 1.0 housing, A/C mod, Billet T-Stat Housing with 203* T-Stat
HillClimber350 is offline
post #3 of 15 Old 08-09-2012, 06:30 AM Thread Starter
This is for my 2000 Excursion, it has the stock cooler only!
I allways heard the stock cooler on the 4r100 wasn't enough for even light towing.
The 170F temp is on my F250 with a 6.0 cooler.
post #4 of 15 Old 08-09-2012, 08:43 AM
7.3Lariat's Avatar
It is certainly better than just one. And you already have it.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #5 of 15 Old 08-09-2012, 08:58 AM
Macon's Avatar
I would be worried about too much cooling when you're not towing.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 15 Old 08-09-2012, 09:02 AM
7.3Lariat's Avatar
Mine still gets up to temp fine even with the dual coolers. But keeps it cooler when it is getting hot.
Mike
SOLD
post #7 of 15 Old 08-09-2012, 05:04 PM
I got u. Yeah ditch your factory cooler and get you another 6.0 cooler.
post #8 of 15 Old 08-10-2012, 08:28 AM
^This is right.
170* while towing is PERFECT. If your tranny doesnt get hot enough, your gonna have just as many problems as too hot. 220* is considered the max, and if your at 170* towing an 18ft, your fine.
85_305 is offline
post #9 of 15 Old 08-13-2012, 06:16 AM
Jrz13's Avatar
If your going to mount that second cooler, don't mount it upside down. Could cause air bubbles in the system.
Forged Rods
ARP Head & Main Studs
Port, Polish, 3 way valve job
Beans 160cc Single Shot Injectors
DI Regulated Return/Oil X Over
DieselSite Coolant Filter
TS 6 position (Beans Tunes)
AFE stage 2 dry
Labonte Stage 3 Methanol Injection
Banks wheels, exhaust housing, wastegate, Intercooler
5in Turbo back Exhaust
Custom Built Trans w/ Billet Shafts
Mag-Hytec Trans Pan/Diff Covers
6.0 Trans Cooler
SnowDogg EX90 plow
Jrz13 is offline
post #10 of 15 Old 08-26-2012, 03:19 PM Thread Starter
Just a update for everyone
Went on the trip, turned out about 3069 miles from driveway to driveway, temps with the twin stock trans coolers were 175f normal max of 191f in stop and go traffic
So I do think this is a good option, and much cheaper than a 6.0 cooler.
