performance/economy injectors - Ford Powerstroke Diesel Forum
Old 08-04-2012, 05:32 PM
does anyone have a list on a site or something about this ? my stock injectors arent liking the fuel being delivered to them so i get the high/low pressure code forget the # for it . im looking to push 700lb tq or so . currently 500-550 . let me know please .
Old 08-05-2012, 06:53 PM
High/Low (oil?) pressure shouldn't have anything to do with the fuel for HEUI Injectors. So, what mods do you have right now and what programmer/chip do you have?
Old 08-06-2012, 07:32 AM
injector pressure higher/lower than desired . not oil .
Old 08-06-2012, 07:33 AM
4" turbo back magnaflow, edge juice , edge programmer im assuming w chip havent checked yet , cold air intake , gagues . are the mods .
Old 08-06-2012, 09:18 AM
here is a site for you
Performance Injectors for 7.3L Ford Power Strokes
Old 08-06-2012, 11:02 AM
Feedback Score: 5 reviews
Get it scaned and check HPOP #'s and IPR %
Give us ALL info on your truck and its mods.
Old 08-06-2012, 11:22 AM
Your stock injectors will take whatever fuel you can throw at them.... These trucks make 550ft-lbs bone stock. You have an hpop/tuning issue.
Correct.
thats why you shouldn't buy edge. It's calling for too much oil. So either your hpop is shot (very unlikely..) or you need better tuning that doesn't require the use of a boost fooler, as your "Edge" does.
Old 08-06-2012, 11:44 AM
All SD 7.3's need a boost fooler if tuned or they are leaving lots on the table.
All SD 7.3's when tuned will run out of HPO as the stock splits are very demanding and require more HPO than a stock 17* can produce.
Old 08-06-2012, 11:57 AM
I wouldn't bother trying to get the small amount (def. not 3qts!) out of the hpop...
Old 08-06-2012, 12:44 PM
Can some-do turn off the check engine code..maybe but its still running out of oil..same goes for a OBS..you can't tune out of this issue unless you limit the fuel being asked for which negates the reason you add larger inj's or get tunes .
