5" down pipe?
Has anyone ever put a 5" down pipe on there 7.3?? I do not see them for sale but it looks like it could be made. I think I am may try it.
the firewall only allows for 4 inch in order to put a 5 inch you would have to cut the firewall but it can be done
Man that would be dang tight if it would even go have to do some mods to firewall my guess
it is not the best pic but looks like a good 6" opening to run a 5" pipe. custom made of course!!
[IMG] [/IMG]
I do not think it would gain any hp or anything like that, but I would think it would give me a lower deep sound, do you think?? would it??
As far as a HP gain, considering the outlet on the turbo isn't anywhere near 5", you'd be correct.
considering you only have the stock downpipe in there, wait til you put a 4" one in there, then tell us if you think you can put a 5" downpipe in there without cutting the firewall and using a big Fn hammer to make that thing fit. You aint gonna gain anything from it at all.
OK, why did ford put the bolt for the down pipe clamp on the back by the fire wall so you can not pry it open after you loosen the nut!!!!!!
Any suggestions please???? |
Cause I think yours was put on backwards...... Just took my clamp off two days ago and it was facing the other direction. And I wouldnt pry on the bolt, the little peice of metal that holds the bolt will bend and is only spot welded. Put a screw driver under the lip of the clamp.
