Need some direction.... - Ford Powerstroke Diesel Forum
Old 07-26-2012, 02:04 AM
Saturday I'm going to look at a 99 f250 with a 7.3. Planning on timing it home if all goes well.
Truck is mostly going to be used for towing. It already has a gooseneck hitch so that's a plus
I don't want to build some hug Hp diesel I just want something that will haul well and I don't have to worry about if I have enough power to climb a hill.
I was thinking
1. 4 or 5 inch straight pipe exhaust. Is there much of a performance differance between the 2?
2. DIY intake
3. Gauges
4. I think Its a tw six position tunner is what I keep reading is a great runner for the 7.3s
What else would be good to add to the list to make power? But not burn 1000s of dollars?
This will be the first diesel I have owned. Work on them every day for my Job but never owned one
Any help would be great
Thanks
Old 07-26-2012, 04:20 AM
4 inch. 5 inch is just a different sound really. No performance. Gauges definitely. TS chip definitely. Maybe stage one injectors with the chip tuned for them if you feel you really need them
Old 07-26-2012, 04:38 AM
I would go with the 4 inch exhaust some people have a problem with the 5 inch hitting the fire wall. You definitely need gauges and I would go with the 6 position chip, if gives you more option for what you can run. Most of the time I only run on a couple of settings. You can get by with your stock injectors but stag 1 injectors would be some inprovement. You should get you a aftermarket intake like a S&B or maybe a AFE intake.
Old 07-26-2012, 12:52 PM
I have a 5 in exhaust but i think it has a 4.5in down pipe with plenty of room around it.
6637(diy) intake
gauges
then if you have them money go for performance
chip tw, dp, php, beans everyone will have there preference personally would run any of them in my truck
hpop depending on your miles yours could be getting weak and will support bigger injectors if you install them later
Old 07-26-2012, 05:07 PM
Ok thanks guys thinking just going to do exhaust intake and tunner for now. The truck has 285k on it plan is to buy this truck run for a year and pay it off then trade for a 6.4
Old 07-26-2012, 06:36 PM
another thing would be to do a fuel regulated return, really help out with fuel economy and make that 7.3 alil happier.
Old 07-26-2012, 07:53 PM
Ok sweet man anything to same some fuel is good too
Old 07-27-2012, 01:48 AM
There's nothing cheap about a diesel, turbo is a grand or two injectors are about that, tranny a few thousand if you wanted to go that route
Old 07-27-2012, 05:36 AM
Dude you actually came back?? For me???? I'M TOUCHED!
isn't that the truth!
