BD Diverter Valve
Anyone have a BD diverter valve, or know someone who does? I can't find jack about this thing being used in a real world environment.
Our trucks dont user diverter valves.. why the heck would you want one installed?
I was curious because it seems that those with a larger turbo would use it to help it spool at lower rpm's, and if someone had one hooked up I was wondering how it performed. Personally, I don't want one. I have no need for a large turbo, I don't and have no plans for towing/hauling anything that might require one.
I had no idea that the 7.3 can't be fitted with one. Sorry, I just was under the impression that it could be bolted on. I guess that's why I haven't found anything about it being on one of our trucks. lol whoops. Thanks for clearing that one up. |
vehicles that come stock with diverter valves, namely European cars, are programmed all the way down to the ECU to use a diverter valve. We have no use for one... super duty's use a wastegate to bleed off excessive intake air charge.
Well it doesn't bleed off excessive air charge it bypasses the turbine wheel on the exhaust side to slow down the the compressor side by spinning the turbine slower.
More accurately represented. Thank you.
Incorrect,
The diverter valve diverts the exaust down to one volute on the turbine. What this does is in fact speed up velocity to get the turbo to light faster at lower rpm. It helps people who have a large turbo to get it to spool sooner. It has a presure canister that opens both volutes at a preset boost presure. The 6.0 guys use them a lot when they go to a fixed geometry turbo. Mostly because the stock up pipes on a 6.0 are open, not divided. Our trucks have divided pipes and a divided ex housing on the turbo, there fore unnessary to run a diverter valve.
I get a little bit rattled when people post answers who don't know what there talking about. In turn people get false information. If you read the original op question it is in fact asking about the bd diverter valve. Now then the information I took time to provide is indeed correct as I happen to run one on my 6.0. And in no way does that valve divert anything to the intake. Nor does it bypass anything by the exhaust. It simply diverts the exhaust gas down to one voulte entering the turbo to speed up spool time. I mean my craftsman lawnmower has a valve under the seat that diverts gas to the reserve tank when I run out of gas. Maybe that's what it is! Lol?!
