Air intake heater - Ford Powerstroke Diesel Forum
Old 07-13-2012, 05:16 AM
Air intake heater
If I delete this how much will cold weather starting be affected. Im not talking bout 30 degrees either im talking below zero weather.
Old 07-13-2012, 12:52 PM
It won't be affected. For the AIH to come on, the parking brake has to be on, voltage 11.8-15, oil temp below 131, park or out of gear on manuals, glow plugs off and air temp below 32.
Old 07-15-2012, 09:10 AM
do you get any ses codes if you remove it?
Old 07-15-2012, 10:11 AM
It shouldn't throw an SES light, but it may set a soft code. Which wouldnt be noticed until you had your codes pulled for any reason..
Also makes a great spot to install a boost gauge
Sent from my DROIDX using AutoGuide.Com Free App
Old 07-15-2012, 02:22 PM
As stated; it's not needed. I have mine removed for 4 yrs or so and it does not effect the truck at all.
It only sets a soft code, nothing to worry about.
