Silencer Ring - Ford Powerstroke Diesel Forum
Old 10-09-2007, 08:33 PM
Silencer Ring
Is pulling the silencer ring only a dodge thing...or can i do it to my 2003 ford 7.3 liter??
Old 10-09-2007, 09:41 PM
I'm thinking that it is only a dodge thing, but here's a bump, lets see what people have to say!
Old 10-09-2007, 09:59 PM
Yeah that is only a Dodge thing. wish it wasnt but it is.
Old 10-09-2007, 10:13 PM
That's what I thought. I just helped my roommate pull the ring on his 07 Big Horn. If my truck has a silencer ring I have no idea where the little bugger is hiding!
Old 10-09-2007, 10:19 PM
COLLEGE KID
Send a message via AIM to lifewitlooie
what is a silencer ring? I think vibration dampener on the driveshaft when i see "silencer ring"
Old 10-09-2007, 10:43 PM
on the cummins turbos, there is a little reduction flange you might say, in the inlet of the turbo, keeps the noise down or some damn chrysler thing. it's a fairly popular cummins mod. we took his out fairly easy, it made the turbo a little louder. it's like the dodge equivalent of foil delete as far as the end result.
Old 10-10-2007, 06:30 AM
what is foil delete? i heard a 7.3 powerstroke around the mall the other day driving around and it looked stock...just a red 4x4 but his turbo was loud as heck!! how would i do that without hurting anything...i just bought mbrp 4" turbo back...will that make the turbo louder?
Old 10-10-2007, 06:37 AM
.......anybody......
Old 10-10-2007, 06:42 AM
Acually the silencer ring is on the early model 03, 6.0's it was cast into the turbo. so there was no way to remove it. The foil delete is a small peice of foil thats added to the turbo inlet pipe to reduce turbo noise. i did it, but feel its a waist of time. There was no difference in the before to after.
Old 10-10-2007, 06:51 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Actually, if you wanted to, you could break out the dremel and grind down that silencer ring on your 6.0L turbo. a little work, but could be worth it. I'm thinking about getting some stock intake peices (Intake spider) and doing some dremel porting. If I could ever find a 7.3L at a JY I would get some heads and mess with porting the intake and exhaust runners....along with getting some stock exhaust manifolds and porting those....might help a little.
