standard transmission question?? - Ford Powerstroke Diesel Forum
Old 10-09-2007, 02:27 PM
is there a way to make the 6 spd shift faster than it does??
would a shorter throw gear shifter help?? or is it possible..
i notice with my truck I cant keep up with the motor..
thanks in advance
Old 10-09-2007, 02:32 PM
i was wondering the same thing....it aint like shifting a small car were you can just bang thru the gears and get going.
Old 10-09-2007, 02:59 PM
BIG TRUCK, SMALL DRIVER
A short throw shifter will not allow the gears to engage any quicker. It will shorten the distance you have to move your arm, but that is not what controls the speed of a shift. Heavy duty trannys just can't shift as fast as smaller ones. I can bang through the gears in mine pretty quickly, but it grinds on every shift. Not good for the long run. You can play with the shift points until you find the sweet spots.
Old 10-09-2007, 03:27 PM
Thats Mr. Oil Leak.....
to Derrick. you can put a southbend clutch (or something) in to help stop the spinning mass quicker but you aint gonna bang gears like a gasser.
