Edge w/Attitude Programer issues - Ford Powerstroke Diesel Forum
Old 07-09-2012, 10:10 AM
I added the Edge programer to my truck. I also added a 4" stainless MBRP exhaust and an air intake setup. The Edge throws a check engine light. Too high/low oil pressure. Is there any way to reprogram the computer to adjust the oil pressure points?
Also after I had it installed when you are running down the highway the boost drops to 0 for maybe 1-3 seconds prob 5-6 times a min for like 10 min then stops for a little then starts up again. This continues till I get off the highway. Is this a defueling issue? I recorded it with my phone showing the programer screen. I took it to the place I had it installed and they said they dont know. They changed out the equipment 3 times. They called Edge and said they dont know why it is doing it. They said deal with it or remove it all together.
Anyone have any suggestions on maybe adjusting the settings or anything to help with this issue?
Thanks
Old 07-09-2012, 10:44 AM
Thanks
Ya... ditch the pos and get a chip made for your truck. Those things create more headaches than they are worth.
The edge is calling for more boost than the truck likes and is limping out more than likely. You probably need a boost fooler. A custom chip made for your truck will not require a boost fooler and will be ready to go.
