Ebpv delete - Ford Powerstroke Diesel Forum
Old 07-08-2012, 12:43 PM
Ebpv delete
Hey guys I've seen these ebpv delete kits where you put in a "power elbow" any suggestions if I should or shouldn't do this. My ebpv is leaking and was searching for rebuild kits and I've seen this is a popular mod. Thanks
Old 07-08-2012, 12:49 PM
You basically don't need it.
You can either delete it yourself or by a non EBPV pedestal and outlet if you feel like just replacing them.
Old 07-08-2012, 12:59 PM
Would I gain anything by deleting it? How difficult is it to delete
Old 07-08-2012, 01:01 PM
There's some threads about this already. More about what it does and if it's needed.
You might lose some backpressure, which is a plus. And eliminate a possible oil leak. Basically it.
Old 07-08-2012, 01:05 PM
Alright thank you I'll do some searching for the threads
Old 07-08-2012, 01:24 PM
not to but in on this but I am not having a problem with mine but was thinking of deleting it for better performance what would I gain??
Old 07-08-2012, 01:47 PM
With less BP comes less EGTs, usually.
Old 07-08-2012, 01:54 PM
What all would I need if i bought a ebpv delete pedestal and turbo o-rings. Will this pedestal deliver the oil to the turbo or does something else need to be added.
Old 07-08-2012, 02:26 PM
The pedestal has all the internals needed, just no EBPV actuating rod or passage.
Garrett Turbo Pedestal NON-EBPV 1999.5 - 2003
Garrett High Flow Non-EBPV Exhaust Outlet
Old 07-08-2012, 02:29 PM
So basically bolting the new pedestal and existing turbo back on and I'm good to nothing extra needs to be done
