turbo surge - Ford Powerstroke Diesel Forum
Old 10-07-2007, 06:18 PM
Send a message via AIM to farmboy930
turbo surge
i finally put my programmer from elite in and wow what a rush of power now im getting some pretty good turbo surge what is the best way to fix this problem. should i get a wicked wheel, a ats ported housing, or a nother aftermarket housing
Old 10-07-2007, 06:42 PM
I installed a banks wicked wheel on my truck this spring and it completely eliminated my turbo surge.
Old 10-08-2007, 05:08 AM
i was thinking about a housing to get a little more air as well also what about that van turbo what is it and what do i need to know to find one
Old 10-08-2007, 05:13 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
The best way is either WW AND ATS housing or just get a replacement turbo, like an GTS or H2E...If I had it to do again...I would have waited and saved my $$$ I spent on my WW and 1.0 exhaust housing and just got an H2E or Fat Shaft.
Old 10-08-2007, 04:04 PM
whats that gonna run me and will the surge hurt my turbo
Old 10-08-2007, 04:08 PM
if you surge long enough it will kill your turbo, but the WW and ATS housing will eliminate most or all of the surge.
Old 10-08-2007, 04:15 PM
i also could use a little more air to clean my smoke up and cool it down a little bit egts hit 1300 with ease and she smokes like a ***** would the ww and ats help that also i sceen discount power parts has a 1.15 non waste gated housing would that be a better choice then the ww and ats
Old 10-08-2007, 04:29 PM
Not too sure to be honest if it will help clear up some smoke, or lower EGT's. I dont have the WW setup or the housing, but I know a ton of guys use it over the stock stuff. Maybe one of the guys that run these products will chime in and shed some light on your questions.
Old 10-09-2007, 06:28 AM
ok thanks for everything so far its a big help and id love to buy a new turbo but i leave for school in june and id like to buy a modified trans with in the next year
Old 10-09-2007, 11:55 AM
Think about how far you are going to go... Are you going to add injectors at some point?
I started with a WW, and it helped, then added the ATS housing, then added the TM wastegate rod, then swapped out for a surging POS garrett 38r, and now have a Turbonetics turbo...
