Boost Probe Location
Hello all,
Just want some input. Ive read different opinions out here. Some say I need to drill and tap my probe into my Spyder Pipe because the line off the MAP sensor is inaccurate in its readings. While others say the MAP line T is the way to go. Who is correct. I know the MAP line hose comes off the bottom of the Spyder pipe so I dont understand how the readings would be inaccurate. Just wanted to see what was the best way to do this. Thanks |
you can put a t fitting in the map line that is what many people do. i did the Air intake heater delete from riffraff and it comes with a optional boost fitting. i personally like mine. it gets rid of the AIH and it provides a spot for my boost gauge.
Either works. Some report fluttering with the MAP line T. Doesn't matter. i pulled and tapped my spider.
Sounds great guys, just to keep it simple today Ill T into the MAP line. As soon as I get another order together Ill order from Riff Raff. Thanks again
Drill and tap spider just did mine yesterday works great
Dodge drain plug, suitably modified replacement for the AIH.
Very nice. I was wondering how to do this, but never got around to it.
Thanks everyone. Like that drain plug mod....nifty thinking. I was bored at work so I went ahead and taped the Spider pipe and installed a new map sensor hose. Ill test it all out on the way home today.
I got a bushing from the hardware store and removed the AIH and that's where my boost is connected
