Wastegate line question
Hey, I know you guys have seen this probably 100x but I wanted to make sure I got my facts straight before jumping into this. I want to unplug the red line from my waste gate and plug it to see better boost numbers but I was wondering if I also needed to do a DIY boost fooler in order to see any effect. Also, will doing this effect my EGTs in any way? Thanks.
Yes you need a boost fooler too.With mine unplugged I got the boost quicker but stopped around twenty pounds.I then added an ats boost fooler and turned it up and now am around 29 -30lbs.I do have a 38r so your numbers won't be as high but the same principal.I just plugged the red line on one of the nearby clamp screws.
Sounds good. Stock right now I'm seeing around 13-14 max. So simply unplugging it, I'll see better numbers but adding a boost fooler will get me even better numbers?
Get a little bit better numbers but stock turbos can't put out alot of boost and will suffer heavy surge without a wicked wheel.
I got a TW chip and I am seeing around 27 pounds on the hot tune with my waste gate plugged in. I have a boost fooler though, and that is with a stock turbo. I do have terrible surge though so I cant WOT much
I am running stock turbo with a boost fooler and a crapy banks chip I see right around 23-26 with no surge really at all. every once in a while I get chatter but thats it.
you do not need a boost fooler on a stock truck or for most of todays tunes. The only time you should need a fooler is if your sel comes on.
I ran DP tuner for 4 yrs and never needed a fooler. Have been running PHP tunes and same thing. I am sure TW among other great ts tuners will be the same. a stock truck will most likely not hit the limits of the map sensor. removing the red line does not gain you much if anything. If you gain a lot by unplugging your red line, then your wastegate actuator is faulty or needs to be replaced. To the OP; do not waste your money on a boost fooler. just unplug the line and see if you gain anything. |
INFRNL that does not make any sense...I know for a fact that at 23psi of boost you will get a code and get defueled..I am seeing a consistant 27 lbs at WOT with TW tuning and once I saw almost 30 lbs with a stock turbo...and I would not be getting those with out the boost fooler. I dont know why your not seeing the numbers or what but I would be talking to DP or PHP about that.
tuners bypass the need for boost fooler through tuning. Maybe Tony doesn't do it, but I'm sure he does. I think PHP's site even specifically states that NO boost fooler is needed. How long have you had tony's tunes? When I got my DP 4 yrs ago it was a new thing to be able to bypass or trick the map sensor through tuning; or at least for DP. There is nothing wrong with my tunes or truck, it pulles like a raped ape all the way from the time I hit the pedal throughout the entire bandwidth. there is no defueling or loss. Call Tony and ask him if a boost fooler is needed with his current tunes; i bet he says no. I have talked to Clay at RiffRaff, Cary from CT performance, Jody Tipton, Bill at PHP among others that have said the same thing. I specifically asked them if I needed a boost fooler cause I was going to buy one. They all said no unless I am setting the SEL light and it creates problems. I have never had an issue. The OP has a stock truck and will definitely not see the SEL light or make more than 22lbs by just removing the red line. I also know for a fact with my truck that I do not get codes or defuel ever going over 22-23lbs. I just might buy a boost fooler to prove you wrong even though I already know that it will not benefit. I am currently waiting for my upgraded turbo though. I will report back after I get the turbo and get it installed. I am not trying to argue, just pointing out what I know and have been told by the tuners and guys selling our chips everyday. Maybe I am just not the best with words, but my statement that no boost fooler is needed still stands. |
Thanks for the info. I stand corrected then...I did not know that they were able to boost fool through tunning...Before I had TW chip I had a programmer and I was constantly throwing the SEL light so I had to get a boost fooler, and I guess I just assumed it carried over with custom chips...Thanks for setting me straight wasnt trying to argue either.
