engine parts - Ford Powerstroke Diesel Forum
Old 10-06-2007, 05:27 AM
Send a message via AIM to farmboy930
engine parts
im thinking on getting elite diesels stage 3 injectors for my 2000 besides trans turbo fuel system and hpop what kind of engine parts should i be concerned about to run that kind of power
Old 10-06-2007, 03:25 PM
Send a message via AIM to PwrStrokinDually
How about some gauges.
Old 10-08-2007, 08:04 PM
You dont need oil for hybrids... Thats part of the benifit of hybrids... I will say that my hybrids smoked less then the stage 2 swamps I was running.
Tadd should have my injectors tomarrow and will be going thru them after the Motor issue I had...
I would say a Turbo (Turbonetics BB), a Tranny and Studs you would be good... Fuel system, dual Hpop's and such can all be done later....
Old 10-09-2007, 06:25 AM
ya well the oil really isnt that big of a problem because my friend knows a shop that can rebuild my stock one and boost the pressure to where it should be for $700 bucks
Old 10-09-2007, 07:30 AM
Cynic
Isn't increased air flow what you want? On the stock housings, once you go over a certain PSI, you are over spinning the turbo. Correct?
Old 10-09-2007, 11:47 AM
I believe he is talking about the HPOP...
If you find a shop that will rebuild your pump and get "pressures where they should be" for $700... Post up the phone number...
Old 10-09-2007, 02:36 PM
ok ill get the number from my friend and post them thanks for all the help as well even though it will be a while before i get the big mods but at least i know now
