Decel tune on dp tuner - Ford Powerstroke Diesel Forum
post #1 of 21 Old 06-10-2012, 09:10 PM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
So I installed a dp tuner with the decel tune. I love the tunes but on the decel tune I dont notice that much difference when activating it. I have not used it pulling a heavy load yet, just a small two atv trailer. I checked EBVP and it's getting power, how else to I check to see if it's closing?
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #2 of 21 Old 06-10-2012, 11:52 PM
JSchuricht's Avatar
You could pull the down pipe off, start up the truck and put 12v to the EBPV. You could also wire in a 12v light to see when it activates, it should make a noticable hissing sound when it is closed. I run mine on a switch manually so I don't know what the requirements are for the tune to close the valve.
JSchuricht is offline
post #3 of 21 Old 06-11-2012, 05:53 AM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
Does it make a bigger difference when your loaded verses empty?
post #4 of 21 Old 06-12-2012, 12:21 AM
JSchuricht's Avatar
Well, it only provides so much backpressure so more weight will push you more. You do need to have your RPM's up, it is basically useless below 2k.
post #5 of 21 Old 06-12-2012, 05:45 AM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
Ok that's what I was wondering. Last night I was listening to the exhaust at the tailpipe and I can hear a different sound when it's turned to the decel tune. So I am guessing that its working.
post #6 of 21 Old 06-12-2012, 11:00 AM
CSIPSD's Avatar
Not worth anything below 2000-2200 RPM's... Its just a little exhaust brake, not going to chirp the tires or anything.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 21 Old 06-12-2012, 11:20 AM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
I guess I was not getting the rpm's up high enough. Thanks for the help
post #8 of 21 Old 06-12-2012, 07:46 PM
Guns & Powerstroke's
HillClimber350's Avatar
Never thought about running it on a switch
2001 F-250 Platinum Edition
BTS Trans, 6.0L Cooler, DP Tuner, AFE Stage 2 Intake, 4" turbo back, Bean's 1.0 housing, A/C mod, Billet T-Stat Housing with 203* T-Stat
HillClimber350 is offline
post #9 of 21 Old 06-13-2012, 10:32 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Might want to read this...
First, in order to transfer the energy of the moving vehicle to the engine during deceleration, two things must occur: the torque converter must remain locked, and the coast clutch must be engaged. The problem with this is that the coast clutch on a stock transmission only has 3 friction plates, and these are smaller than the standard forward clutches. On 2001 and later transmissions, you also run the possibility of damaging the intermediate sprag or "diode," which will result in an immediate transmission teardown. Again, lightly loaded vehicles would have less of a problem with this, but the general idea of an exhaust brake is to be able to slow larger loads without overheating the standard brake system. It is these types of loads that can cause transmission damage.
CT Performance, Inc. is offline
post #10 of 21 Old 06-13-2012, 11:38 AM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
How do I know if the trans is a 2001 or later. It's a reman from ford that was put in back in 2006. Plus I did not know there were differences in the 4r100's.
