Ordered my chip today - Ford Powerstroke Diesel Forum
Old 06-08-2012, 06:18 PM
Or my chip today with tunes form beans cant wait toget it and install it... pumped
Old 06-08-2012, 09:28 PM
Congrats! hope you already have guages.
Old 06-09-2012, 04:19 AM
i do have guages also exhaust and intake and boost fooler
Old 06-09-2012, 08:36 AM
Then your set. Let us know what you think. Make sure you really clean the connector on the PCM. Just be careful not to remove the tinning on the contacts.
A brass brush, toothpicks and green(brown) pad should be all you need. I had copper showing on the contacts but still worked fine, but I decided to retin the contacts myself to be safe. The tinning helps protect from corrosion from any moisture.
I am sure the chip will put a huge smile on your face. You will have a perma-grin every time you drive it till you decide to get your mileage back
Old 06-09-2012, 11:58 AM
yeah i hoping to get 2 to 4 mpg added with the dd tune but i know what yo mean about loosing mpgs when i first get it. is it hard to install
Old 06-09-2012, 12:35 PM
It's a breeze to install, just have to take your time cleaning the connector on the PCM. I imagine beans will send you instructions; if not they are easy to find.
After doing it, you can access or swap the chip in less than 15 minutes. I recently cut out the plastic on the PCM cover; so now it just takes a second to pull the chip.
Old 06-09-2012, 12:44 PM
where is the pcm.. driver side by the emergency brake ?
Old 06-09-2012, 12:49 PM
Yes. It's inside that black plastic cover. If you look inside the engine compartment on the firewall; you will see a big connector connected to it. The connector takes a 10mm socket. The screws for the PCM cover are 7mm.
Old 06-09-2012, 12:52 PM
thanks alot
Old 06-09-2012, 01:05 PM
Np. Let me know if you do not end up getting instructions, I will help you get them
