Injector Questions
I have a couple of questions about aftermarket injectors. I live in California so the smog rules are pretty strict. I need something that will give me more power, hopefully with other mods I can make up to 400-450 hp, and I need them not to smoke. When smoging a diesel in California they do a smoke test, if it smoke even a little its an automatic fail. I was wondering if stage ones would be enough or is this idea even possible. If this is possible what would be a good set to get. With custom tuning is this 400-450 hp mark obtainable. Thanks in advance.
you might be able to get a smog tune that is smoke free. but its really hard to make 400 with stage 1's
Couldn't you get to the HP level you want and just run the modified stock setting when you get your test done? Maybe I read the post wrong. I know there are people in Cali running what you're after.
What year?? 2001 newer stick to stage 1's..you have PMR's...bigger and you will risk them.
INFRNL when I take the smog test I cant have any programing in the truck. But if I can hide the switch for my TS chip I could propably do that. Is there anyone who makes smoke free tunes for a TS style chip? CT I have a 2000 so is there something you would recommend.
If the inspector see a chip you will fail.
You can't run a single shot truck with single shot inj's.. TW tunes are what we recomened for 7.3's. You may be stuck with stock splits..then best mods are a SRP1.1, TW tunes and if the inspectors don't care a reg return... |
Ok I'll look into it CT, thanks for the info.
Cali must be strict. Here in Colorado, I tell them I have a chip but it's on stock setting; they do not care as long as it passes. This is why I said what I did.
Stock tuning will not smoke. Some of the tuners do better than others at eliminating the smoke but it shouldn't smoke unless you are on 120/140 setting, possibly 100hp setting. I know PHP tunes are good about smoke and I think TW tunes are good about minimal smoke. CT (caryt) can set you up with TW tunes and has the best prices on many items. I think you need to find Cali guys or guys in your area to see what they are doing. I know there are guys in Cali with upgraded injectors,etc without issues for smog testing. If you have a 2000, you should have forged rods and can teach your goal easily |
Well INFRNL the guy I take my truck to does not care that I have a chip as long as it is on the stock setting, but if I put stage one injectors in my truck its propably going to smoke. Isnt it? If my truck wont smoke with stage ones and no chip then I dont have to worry, but if my truck needs a tune so it wont smoke then I will need to hide my chip. My smog guy can bend the rules a little but if he knows that I have a tune going to my truck during the test he will fail me.
with your chip having injectors and keeping stock tuning will require what they call a modified stock setting. This is basically like putting your truck back to stock now excepts it it tuned/programmed to run your single shot injectors without issue. As far as I know; there will be no smoke just as your stock truck is now. Hopefully someone will clarify this in better words/detail. |
