Trans Temp, low reading? - Ford Powerstroke Diesel Forum
Old 05-02-2012, 08:26 PM
Once you go black......
Send a message via MSN to CanadianDiesel
I just installed A-pillar gauges (Autometer), boost works fine (17PSI wot), but Trans Temp only went up to about 150*F?. Bad sender? Or is that what it should read?
Needle doesn't drop back down on shutdown, not sure if that's how Autometers are though...
Old 05-02-2012, 08:33 PM
isn't it pretty cold in canada. seems normal to me. 80-90 above ambient is about right
Old 05-02-2012, 09:07 PM
My trans temp on my banks PDA reads about 160*F. Cant see it when truck is off
Old 05-02-2012, 09:32 PM
i live in alberta and have around 130-150f , the reading is of my h&s minimax . but mine is a 5r110 and i think your is a 4r110?
Old 05-02-2012, 10:34 PM
Depending on where I'm driving and the temperature, my trans will also stay around 150. It was 90 outside here today and my trans was around 160-170. If you go out and beat on your truck the trans temp will raise, it's just not instant.
Old 05-03-2012, 03:19 AM
Send a message via AIM to rufushusky
That sounds about right.
It is the 4R100 behind the 7.3
Old 05-03-2012, 03:41 AM
Almostdunfukinwidit
Its about right.
80-90 degrees above ambient is where it will be.
Now if it were a 6.0 it generally wont get much above 165 in the summer because of the huge cooler
Old 05-03-2012, 04:10 AM
Sounds like your trans is perfect.
Old 05-03-2012, 05:26 AM
Alright, turns out I was wrong about 150 (I can't read??). It went to about 130, but last night when I tried her out it was about 50-60* ambient temp... Does that still sound right? I was driving it hard enough, and then one of my calipers seized....
Old 05-03-2012, 05:41 AM
Ronning cool is good as long as your tc oud warm enough to lock up
Heat its bad
I made my Samsung SGH-I997 send this.
