transmission upgrades? - Ford Powerstroke Diesel Forum
Old 04-24-2012, 06:31 PM
Hello guys got a question for ya. I have a 2000 crewcab 7.3. I am doing a few upgrades to it. bigger injectors, bellowed up pipes, chip. I will be adding about 150hp to the truck. what upgrades can i do to the tranny with out rebuilding it to help it hold up ? I know about a billet in-put shaft. I have heard about the 6.0 converter. but what else could be done? also if the 6.0 converter is true what do i need to make it work?
thanks guys
Old 04-24-2012, 06:59 PM
get a bts valve body and a 6.0 cooler, fill her up with schaeffer's all trans and refrain from drivin like idiot and it will last. what size sticks you wantin to go with?
Old 04-25-2012, 03:28 PM
i have a set of stage two's i am puttin in it. they are the singel shot injectors. i had a custom ship burnt so they would work in my truck. i am askin about the trans cause i was told to put a billet input shaft in it and a 6.0 converter. but i was not sure that the converter would work.
Old 04-25-2012, 05:20 PM
well http://www.powerstroke.org/forum/mem...ance-inc-.html sells 6.0 tc's but the bts valve body and cooler is what a lot of people are runnin. i don't think you'll be makin enough power to need a billet input shaft
Old 04-27-2012, 06:33 PM
i am just afraid to trashin it when i get on it. wont adding 150 hp trash the trans is it hooks?
Old 04-27-2012, 06:45 PM
if you add stage 2's (160/100's) with a stock turbo you're still only gonna make 400ish horse before the turbo poops out. lots of people are makin a lot more power than you on stock with bts valve body
Old 04-28-2012, 04:13 PM
so your saying along with the stage 2's run the bts valve body?
Old 04-28-2012, 04:39 PM
Isnt that what ive been sayin since my first post
Old 04-29-2012, 08:53 AM
making sure i was hearing you right
Old 05-01-2012, 03:20 PM
BTS or JW valve body? Im in same boat but will be towing lots of weight.
