other mods?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-27-2007, 04:21 PM Thread Starter
cstroke69cpy3's Avatar
other mods??
ok i read a while ago in another post of some free mods
what mods will help me??
I know i'm overboosting already so i either have to do the regulator or the electrical resistor..
what else can i do and what will the gains be
thanks in advance
chris
EARLY 99 PSD. 7.3 F 250 SUPERDUTY LARIAT, 6 FT BED SUPERCAB. 6 SPEED 4X4. 65,000 MILES,
MODS TO DATE:
4" MBRP TURBO BACK
TYMAR FILTER CUSTOM FABRICATED STAINLESS 45
DP ADJUSTABLE CHIP 60 HP TOW/80 HP ECONO/120HP RACE
pillar mount, isspro gauges egt, boost, fuel pressure..
cstroke69cpy3 is offline
post #2 of 9 Old 09-27-2007, 04:35 PM
rankroddin250's Avatar
fill the blinker fluid! and repack your mufler bearings. thats always good for about 10Hp oh and remeber every sticker on your back window gains 5hp each esp the little dude peeing on a bow tie or a ram. those two stickers are stackable also for a 15 HP gain.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 9 Old 09-27-2007, 04:39 PM Thread Starter
what if im standing in the back peeing on rams and chevys
10-15 hp??
MODS TO DATE:
4" MBRP TURBO BACK
post #4 of 9 Old 09-27-2007, 04:49 PM
thats good for 20Hp like a small shot of nos.
theres not allot of free mods you can do to your truck.i would think you would be prety happy with the mods you have. you could try the 10K mod its good for a little better throtle response. other than that powes gone staryt to cost you some coin at this point in the game.
post #5 of 9 Old 09-27-2007, 04:53 PM
although not free. fairly in expensive you migh make or buy a boost fooler. to keep your computer from defueling the motor when you reach above 25LBS of boost.
post #6 of 9 Old 09-28-2007, 03:02 AM
do the Zoodad -- and try the diode for the boost fooler since that is the cheapest route, then go to the manual boost fooler if the electrical one doesn't work
Blue01F250 is offline
post #7 of 9 Old 09-28-2007, 07:52 AM
Ramsmoker's Avatar
Cool Mod's
The boost fooler is a must. Take a look in my garage and see the 4" tube from the grille back for true ram air. For $100.00 you can build my AFS system to remove air totally from your fuel. Cuts engine noise in half and has seat of the pants performance. I can e-mail pic's and answer any questions you might have. Best thing I ever invented.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #8 of 9 Old 09-28-2007, 08:22 AM
Slated4greatness's Avatar
Quoted: 3 Post(s)
Spend a few hours with the truck: Check tire pressures and rotate. Check and top off all the fluids. Grease all the fittings that have zerk fittings. Just check all the small things, it adds up.. This the only "Free" mods that I am aware of besides the Zoodad.
2006 Dark Slate F350 CC LB 6X6 Lariat Tow Boss edition, Complete with training wheels.
BPD VK688 Kit, W Pump, EGR, FICM, Decked block & Heads, ARP's, Coolant filter, RR, Aux coolant lines, Train Horns, SCT W/GH tunes, Recon smoked LEDs, Pressure pro TPMS, Firestone air bags, Alpine/Infinity/Polk sound system, CTS Monitor and Autometer analog backups. MPG Max Water injection with custom 17 gallon tank. 4" straight to 6" Aussies.
Slated4greatness is offline
post #9 of 9 Old 11-27-2007, 12:16 PM
pojo4223's Avatar
Send a message via AIM to pojo4223
Well they arent free but realllly cheap, you could also do the IDM Mod and the CCV mod, FRP Shim, little things like that can add up...definitely do the boost fooler as well.
-PJ
~Early 99' F350 PSD 4X4~
>Tymar 6637 intake
>Edge evolution
>CCV Mod
>FPR Shim
>HPX Oil Line- Performance Oil Products
>TC Lockup Switch
>BFG All Terrains 305/70/16
>IDM Mod
>Isspro Gauges- Pyro, Tranny, Boost
>FBD 4" Turbo Back, Straight Pipe Exhaust
>Ford Re-manufactured Tranmission
>Rebuilt Stock Garret Turbo. (Parts from Ron's Turbo Service)
What's Next
>BTS Valve body (hopefully sooner rather than later)
>Lit Tow Mirrors
pojo4223 is offline
