Question with Transmission temp. guage.
Im gonna be installing a trans. temp. guage on my 99.5 f-350, i was just wondering if i can use a "add a circuit" and tap into the headlamp fuse instead of taping into the wire behind the headlight switch. Also does the guage need a constant 12v supply and a accessory? or just a accessory?
Switched circuit is what you need. Gauges don't need power when the engine is off.
Hook the gauges up the way the instructions call, if they call for a constant hot, then you should hook up a constant hot. Not correct, some gauges require a constant hot to operate correctly. Get your facts straight before posting, or dont bother. |
Thanks for the replies, yes the guage only requires a switched circuit.
as for the light in the guage the instructions call for the positive to go to the 12 volt light souce, and the negative to a good ground or a dimming circuit.. not to sure what "dimming circuit" means. I would have thought the + from light would go to the dimming wire behind the light switch and the negative to a good ground... sorry if i sound like a tool here guys im just not very knowledgable in this dept. cheers |
