Good Injectors - Ford Powerstroke Diesel Forum
Old 09-26-2007, 10:55 AM
Send a message via AIM to HillBillyDelux555
Question Good Injectors
What kind of injectors are good but not too expensive? Also, do have to get a set of them, cause I have a friend with a cummins (or cumapart) and he said he only got 2 100hp injectors. It still runs, but can you do that with a Powerstroke?
Old 09-26-2007, 11:10 AM
International Threat
Injectors ordinarily require specific tuning to run properly and if you have different injectors then it'll likely be off. I've never heard of running different injectors but that just sounds silly.
Anyway - injectors for cummins and powerstrokes are completely different. A whole set of big injectors for Cummins cost less then 800 bucks while 3 of the 8 injectors for your truck cost 900 from Alliant.
What supporting mods do you have on your truck besides what is in your signature and we can tell you more about which injectors to go with!
Old 09-26-2007, 11:12 AM
(Early) 1999 F-250 7.3L, 2wd, Edge Evolution, Camo seat covers, sound system, custom tailgate, tinted windows,
4 inch straight pipe, 6 inch tip, auto tranny, long bed, extended cab, 260,000 miles, goin for the big 300,000.
Those are the only power mods I see on your truck - do you have anything else? Intake? Turbo? Gauges???
Old 09-26-2007, 11:15 AM
fixin to put in a DIY intake, stock turbo, gettin a Quadzilla Commander for myself on my B-day.
Old 09-26-2007, 11:24 AM
Skip the stock turbo and jump up to something like a TN... especially if you're going to be upsizing in injectors. Ge ready to dump 1800+ bucks on injectors if you do it yourself.
Old 09-26-2007, 02:25 PM
hey Marty, what do you think about the DIY-Injector kits. Stage II kits claim about 50hp for $585.00 Those kits worth looking into in your opinion?
Old 09-26-2007, 07:10 PM
lukecline
Guest
Posts: n/a
No you cant do different sized injectors in either a powerstroke or a cummins, i
dont care what your friend tells you. if you want cheap and you have decent mechanical ability try DIY-Injectors.com or if you dont want to do them yourself Beans Diesel Performance.
Old 09-26-2007, 07:15 PM
I second that...it doesnt matter if its a gasser or a diesel.....you cant run different injectors in the same motor at the same time and expect good results. Id caution heavily on the DIY injectors....if you arent SURE you can do it right....dont attemt it. It is do-able but its not something for your average joe eitehr...
Old 09-26-2007, 09:03 PM
If your injectors are in great shape you could do it, but like Marc cautioned you only want to do it if you're absolutely sure you can do it right. There are people out there that have never touched an injector before and did it and it worked... but they won't be holding the bill if you screw it up.
Old 09-27-2007, 05:34 AM
Yes I agree with you Luke, Marc, and Marty with the DIY's. I have done a few injector replacement jobs on the International tow trucks that my boss owns and they went very smoothly. But then again on the other hand I have never disassembled an injector to get to the internal parts, but I feel pretty confident I could handle the task. I'm very good mechanically and learn quick so I think I'm gonna look further into the DIY's. Maybe I'll have an install write-up for all of us within the next month or so.
