mod list from stock
if you all had a stock truck to build.. how would you go about it?
what mods and in what order? |
Well i would do headlights, ccv, 6637, 4in exhaust, gauges, 6.0 tranny cooler, bts valve body, ts chip with beans tunes, regulated return, 38r. After that it depebds on the health of the hpop and whether or not the engine has pmr..
what is the ccv and the bts valve body?
crank case vent mod and a modded valve body by brians truck shop
Bruce what are the benefits of the ccv mod? Clean up engine bay? Is valve body all you think on a tranny? What about the converter? What all will you gain with a valve body?
The ccv mod just diverts the oily gasses away from enterin the intake which then collects in the ic causin oily boots. Petroleum deteriorates silicone so its rough on boots. As for tranny i suggest cooler and vb, tc can be done but i dont suggest gettin a super expensive one one because if the trans lets go and debris enters the tc its done, you'll never get it out with cuttin it open which is costly. Also bts allows you to use the vb later on down the rd in a full build.
How indepth is a vb install? What kinda money for vb? What benefits? Longevity, shift differently, help with slippage?
subscribed
Fat finger from my phone. |
A question for you all.
It's the wife's rig. 180K on the clock and other than an aftermarket air intake system and filter it's stock. I do run 33" tires. Is the CCV and the VB something that would help keep this thing alive longer. We have had no real big problems with this thing. In the process of replacing the HPOP and IPR. I have also done all the fuel o rings from Guzzle's. One more question. Is there a write up on doing the CCV and VB with instruction? Thanks. |
