Whats the best upgrade order? - Ford Powerstroke Diesel Forum
Old 04-10-2012, 03:49 PM
Was thinking of buying that Snow water/meth set up next week. I plan on HPOP, Injectors, and turbo this summer. Is there a "right" order in witch to purchase these items? Its a daily driver and I pull a 14k fifth wheel. Just not sure what my limits are. Im sure a rod or tranny is gonna go just not sure whats gonna be first!
Old 04-10-2012, 04:41 PM
I would wait and do water last to see if you still need it. Turbo is gonna bring egts down. I would do turbo first, then injectors and hpop at the same time that way you only have to get your chip teburned once.
Old 04-10-2012, 05:09 PM
I have the FU chip from PHP so I think they can upload or email my new tunes I think? If you had to pick between the last two what order would you do them? Im already at 24+ psi boost now and I think I read on here that the map sensor only reads to up around that. I am using Edge Insight for gauge so im reading off the map sensor. How much before I need new headstuds? And when a PMR does let go what all of these aftermarket parts am I gonna ruin if any? Thanks in advance for the help.
Old 04-10-2012, 05:14 PM
How big of an injector are you lookin to run? 160/30 with the 38r and an srp1 would be a solid 400 horse set up. You need to do fuel system mods, regulated return and hutch at least. And between the injectors and hpop it would depend on the health og the hpop. You have the insite cts, what is icp and duty cycle.
Old 04-10-2012, 05:17 PM
160/30's won't run ok on the stock HPOP?
Old 04-10-2012, 05:29 PM
Well they are a codes with faster nozzles. Depends on current hpop strength really, but you wont break 400 on stock hpop. Oil is king with heui
Old 04-10-2012, 05:30 PM
I have no idead what ya mean? Can I check that stuff with the Insight? I'm not a mechanic, I buy the stuff and pay someone to install it.....
Old 04-10-2012, 05:40 PM
yes the icp should be labled icp from what i've seen in pics and duty cycle will be labled ipr %
Old 04-10-2012, 05:47 PM
check it while idleing?
Old 04-10-2012, 05:48 PM
no, wide open throttle run to like 90 mph
