Rebuilding a Turbo - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-08-2012, 06:08 AM Thread Starter
Rebuilding a Turbo
I have an aftremarket turbo, 38r I believe? It was on the truck "01 Ex 7.3" when I bought it. Was told by mechanic that it's leaking. My question is, can the turbo be rebuilt or do they just get replaced?. Or would it be better to go back to stock? Truck is stock except for 5" exhaust DP Tuner. I saw remanned stock turbos but not any 38r's Thanks
marmon is offline
post #2 of 20 Old 04-08-2012, 06:40 AM
Quoted: 14 Post(s)
Supposedly the 38r isn't rebuildable but I haven't ever heard why, exactly.
ttyR2 is offline
post #3 of 20 Old 04-08-2012, 09:57 AM
Take a pic of the turbo, 38r's are rebuildable but it costs as much as a new one. And what exactly is it leakin?
bruce51d is offline
post #4 of 20 Old 04-08-2012, 10:11 AM Thread Starter
It's leaking oil. Just had the pedestal replaced now mech. says the turbo is I don't know from where exactly. I can take a pic later and post it.
marmon is offline
post #5 of 20 Old 04-10-2012, 06:35 PM Thread Starter
There are no markings or casts on my turbo to tell me what kind it is or if it's stock or aftermarket. The PO told me it was a 38r?. If I go back with a stock turbo will it bolt right back up with out any mods and will I notice any considerable power loss? I have 5" turbo back exh. DP Tuner and DIY6637 intake. I don't do much heavy towing, Ski Nautique and an Airboat from time to time. Thanks
marmon is offline
post #6 of 20 Old 04-10-2012, 06:38 PM
yes a stocker will bolt up, you won't feel much power loss, surge might become an issue. measure the inlet size, if its not 4 inches then its definitely not a 38r
bruce51d is offline
post #7 of 20 Old 04-10-2012, 06:47 PM Thread Starter
It had a K&N cold CAI on it I removed the filter end and the DIY6637 fit on the intake hose so unless it necks down it should be 4" inlet right> Also can you explain surge? Thanks
marmon is offline
post #8 of 20 Old 04-10-2012, 06:56 PM
yes, surge is when like the turbine side of the turbo over speeds, it happens in modded trucks especially when towin. 38r's can't surge as they were designed not to
bruce51d is offline
post #9 of 20 Old 04-10-2012, 07:03 PM Thread Starter
Thanks. Ok so if I won"t see a big diff in performance I may just go back with the stock turbo. I've seen some on ebay for a good price, unless there junk and I should stay away from them
marmon is offline
post #10 of 20 Old 04-10-2012, 07:07 PM
38r are like 1300 right now, and they are a huge upgrade over stock. i would hate to know i had to go back to stock (hard to because i'm runnin a t4 mount) if you can swing the 1300 do that, if not you don't really have a choice
bruce51d is offline
