Question on Boost Pressure
Hey guys wondering why my edge juice with attitude will not read over 24.7 lbs of boost. I have a PHPchip dieselsite wastegate controller that I have tightened up and I cannot get the gauge to read anymore than 24.7 also I don't have boost fooler maybe thats it any help would be good
have you checked for leaks.
I'm not real familiar with the Edge "gauge" setup. Is it pulling boost from the MAP sensor? If so, don't forget that the MAP sensor reads in absolute pressure, not sure if the Edge has a setting for correction to read actual boost pressure, but if so the setting may be off. "Standard day conditions" would be 14.7 psia.
-Aaron |
Also...With that tuner that you are using you might not see much more than that. My Edge Evolution would only get me 21psig, but when I switched to DP Tuner I could get right around 30psig on my stock turbo with the wastegate closed. 24.7psi is pretty close to the upper limits of a stock turbo and if you are setting a check engine light that stays on for a few minutes and goes back out then you are probably defueling.
-Aaron |
All your reading is a computer input right now. I never trust those until I compare to an actual reading. |
It may be that these tunes trick the PCM into seeing a max of 24.7 from the MAP? Since anything over that would set a light. Just my guess from reading PHP website as I am interested in chipping my truck in the future. |
-Aaron |
No worries. I think a manual boost gauge is the ticket.
Thanks to all of who have responded just to clarify the Edge chip is off only using it for a gauge I am not sure on how to check for leaks the engine light comes on and stays on for a few days because I do not run the truck all the time it only seems to come on when I spike the turbo like with a WOT and a hard downshift situation like getting on the highway. Also I have been tightening up the boost controller from Dieselsite on my turbo and just not sure how far you can go with that but 24.7 is the max I can see on the edge display
i dunno but my edge with attitude reads my boost so far, up to 30 psi. Not sure if it will read higher but i have always been able to go over 24 no problem.
