Early 99 dp tuner boost numbers
I have a e99 with tymar intake and 4 in exhaust and dp tuner on 120 race I can only hit 20 psi I have boost line tapped into my map line and my over boost thing is tapped into the same line. Is that why I'm only seeing 20 psi because the overboost pops off and that's what the gauge reads. I have no leaks anywhere no up pipe leaks there's no soot on the fire wall
i have mine tapped into the AIH and mine reads about 24 to 27 psi on my race tune.
Ya I know that's what im suppose to have idk what it could be. I have a glow shift vacuum/boost gauge I dont need vacuum so I wounded if I just bought a regular boost gauge the reading would be different
Just tightend up all the boots non were that loose went out put it on 120 and mashed it at 35 mph and the gauge went to 22 then after that it went back to 18 then 22. Truck runs mint and I almost forgot how much power it had untill i just did that I'l just gunna go over the boots tomorrow and leave it.
I have an early 99 with an AIS filter and DP tuner with 80E as my highest tune and can hit 24PSI with it. In the 60E tune i can get 22PSI.
If I'm hitting 22 and its running fine and my mpgs are good it's probably not a leak it's might be they gauge but if it reads good up to 20 psi I'm fine with that
It's a boost relief valve on the line about 5 inches from the boost gauge tap
Same thing different name, they are all just pressure regulators that dont allow the MAP sensor to see past a certain PSI. Which would have the same effect on your boost gauge if it was tapped in after the pressure regulator not before like it is supposed to be.
I am running the intake in my sig, and im hitting consistent 24-26 PSI with my Tony Wildman tunes. I also upgraded to a 17* HPOP on my E99
