Check engine light. - Ford Powerstroke Diesel Forum
Old 09-22-2007, 12:57 PM
Check engine light.
I recently installed the Bully Dog F250-F350 02-03 AUTO 6 POSITION 4-BANK CHIP. When you put it on 125 and really get in it, the check engine light will come on for a min or two and go out. Im new to the whole diesel scene and any help will be appreciated...
Old 09-22-2007, 01:10 PM
Overboosting
And welcome to the .org besure to introdue urself
Old 09-22-2007, 01:25 PM
yup its either overboost code or HPOP over/under desired level which are both perfectly normal...
Old 09-22-2007, 02:14 PM
Rob Rob is offline
DITTO to the above!!!!!
Old 09-23-2007, 12:03 PM
Ok thanks for the help. Is there anyway to keep the light from coming on? What pressure does the the light come on? I currently do not have gauges. That is my next purchase. Will the 125 setting hurt anything? I only have the chip. Im still running stock exhaust with the muffler removed and a K&n filter. Also what is a good intake? Like i said, i am new to all of this. Been running gas burners all my life. Thanks guys...
Old 09-23-2007, 12:39 PM
i would get gauges u could possibly tear something up a pyro at the least but you should get boost/EGT/ and Tranny if u have an auto. and You can make a map fooler or buyone online u can make it for like 10 bucks get a air pessure gauge set it to 20 psi using a compresser and get to 1/4 barbed NPT 2 hose clamps and a t then cut the map line and tie the two ends to it with the hose clamps. You can alsoget a diode for a dollar on ebay I am not sure about how those work or you can get a plug and play for 30+
Old 09-23-2007, 02:04 PM
With the gauges just do standard mechanical or something like the bully dog outlook monitor? I have the bully dog 6 position chip. Is the outlook monitor compatible with the chip? What brand air intake?
Old 09-23-2007, 02:08 PM
as for Air intake the best is the AFE stage 2 with pro guard 7 filter... im not 100 percent sure if BD outlook will work i dont sell a lot of bully dog products but im sure their will be someone around to answer that question...if you want to go with a digital display you can get the quadzilla commander or the MSD DashHawk Display
Old 09-23-2007, 02:15 PM
the digital stuff is just plug and play vs the gauges being mechanical correct?
