Helper pump - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-21-2007, 03:11 PM Thread Starter
sttstroke's Avatar
Helper pump
What is a good helper pump for the money? Would it help with stock injectors? My extreme tune seems same on top end as the street tune I thought maybe more fuel would help.
sttstroke is offline
post #2 of 12 Old 09-21-2007, 03:21 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Your high pressure oil pump probobly isnt keeping up. Your fuel pump should be good enough with stock injectors.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 12 Old 09-22-2007, 12:18 PM Thread Starter
sttstroke's Avatar
Natrually, it had to be expensive.
post #4 of 12 Old 09-22-2007, 12:54 PM
Powerstroke Techie
alabamafrog's Avatar
It could be either one, you can always put a guage on it and see if either is loosing pressure. My fuel pressure was falling off and my high setting ran about the same as my low setting. I did these fuel system mods Shutterfly | View Shared Pictures for about $35 and did the FPR mod and all is better now. My fuel pressure was going from about 50psi to 0 when I stomp it, now it runs around 80psi and drops to about 50 when stomped.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #5 of 12 Old 09-25-2007, 02:07 PM Thread Starter
sttstroke's Avatar
I going to do the fpr mod this weekend and see if it makes a differance
post #6 of 12 Old 09-25-2007, 02:10 PM
CSIPSD's Avatar
It wont... You are running out of ICP.... Just a matter of fact... You can shim the regulator and it might idle a bit better but its not going to give you any HP...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 12 Old 09-25-2007, 02:13 PM
Lord Tauk's Avatar
Why would the fuel pressure drop at WOT and be higher at idle? Is there something I'm missing?
Lord Tauk is offline
post #8 of 12 Old 09-25-2007, 02:31 PM
CSIPSD's Avatar
Couldnt tell you...But 90% of the people that do this report a smother idle and thats about it...
His issue with low power at the higher settings will not be helped by the FPR shim. He is not running out of fuel, he is running out of oil...
Joe
CSIPSD is offline
post #9 of 12 Old 09-25-2007, 02:34 PM
Lord Tauk's Avatar
Yeah I gather his issue is CSI but Im talking about Alabama's posts.
To me logicially, the fuel pressure should be more at WOT than at idle not vice versa as he reported, but maybe it's different our PSDs? I never looked at what I get for FP readings.
post #10 of 12 Old 09-25-2007, 02:36 PM
CSIPSD's Avatar
No, because our injectors suck it out of the rails, and without a boost type compensating regulator the pressure goes down... Not to mention our fuel system (thanks FORD...) sucks...
Joe
CSIPSD is offline
